Question about Keurig Platinum B70 Coffee Maker
My Keurig will not brew. It says it is brewing and only a about a teaspon comes out. I've already done the paper clip cleaning method. The water eventually comes out of the vent.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
The keurig is broken it probably says De-Scale its useless you can try all the vinegar and all the poking i know a site that sells them for cheap!!!!
iLikeNew it has tons of keurig parts
Posted on Nov 12, 2010
  • naughtynaugh Nov 12, 2010
    i know this site, iLikeNew
Wil not brew
Try Using a paper clip or long pin to clean the 2 tiny holes in the upper prong that pokes thro the top of the coffee cartage. I had the same problem and that fixed mine
Sep 16, 2015 | Keurig 2.0 K550 Brewing System
It delivers 8.5 ounces when i push the 10 ounce button
Your brewing system needs cleaned. I fixed this problem in my Keurig with a paper clip. Here's a video clip to show you how: http://www.bing.com/videos/search?q=how+to+clean+a+keurig+coffee+maker+with+a+paper+clip&FORM=VIRE2#view=detail&mid=CDB2C4A770BF1E840424CDB2C4A770BF1E840424
Apr 15, 2015 | Keurig B3000SE Large Office Brewing System
My Keurig mini sounds like it is brewing, but nothing comes out.
Could be a clog. Open the brew head a insert something small (like a paper clip) into the water output shaft. Swirl it around to break up any deposits there and then run again (without a k-cup). If water comes out but not correctly, repeat cleaning. Also, check to see if hot water is being deposited back into the tank. This will indicate a clog in the output line (line or, more likely, the head). If cleaning the head does not work, then reset the machine by unplugging and plugging back in.
Aug 16, 2014 | Keurig B30 Mini Coffee Maker
Keurig not brewing
Our unit (the mini) would only blink red but would not brew. It didn't make any noise and seemed like it was dead. To fix this, leave the unit plugged in but powered off. If you haven't already done so, add water to the top of the unit and then open the pod holder so that the water flows into the internal storage tank. Hold the brew button in (don't let go until it is done brewing) and the light will turn on - after a while it will start brewing. Let go of the button once it has finished brewing. According to a Keurig rep - this problem is often caused by using cold water straight from the fridge.
Sep 17, 2013 | Keurig Coffee Makers & Espresso Machines
Coffee maker goes thru all set up but after pushing the start button no water comes out. What can you do to unclog the machine?
Sounds like air in the line or a clog. The first thing I would try is to clear the air in the line by plugging the over flow with your thumb. Cover the overflow and then start to brew a cup of coffee. If it is air in the line the air will blow out into the water tank. Once that is done retry to brew a cup. If that doesn't work use a paper clip to clean out the top nozzle that punctures the K-Cup. You tube has a video on how to clean that out with a paper clip. --snapshot4
Jan 18, 2011 | Keurig Platinum B70 Coffee Maker
Water does not seem to be getting to the heating area
I'm not sure if your saying it does not brew a cup of coffee at all or it is brewing but only cold water comes out. If it is just sitting there making a whinning noise and not delivering water it may just be dirty. To clean it you need to fill the resivior with a 50% white viniger and 50% water mixture. Run a brew cycle and let it sit for an hour. Then run several cycles through until it is out, refill the resivior with water only, run it completely through and continue with the water only until there is no more viniger smell or tatse. You will need to clean the brewer needle heads as well. Lift the handle to access the coffee pod compartment, remove the pod basket and use a paper clip to clean out the hole in the puncture needle. With the lever still raised, use the paper clip to clean out the three holes in the upper needle head. Replace the pod basket, close the handle and run a couple brew cycles through without a coffee pod.
Nov 24, 2010 | Keurig B100 Coffee Maker
Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Mar 25, 2010 | Keurig B60 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
952 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
