Question about Panasonic Televison & Video
I have a Panasonic DMR-EX83EB and suddenly the display just reads AVI and it's no longer getting a TV signal so it's stopped recording things it was set to record (or, rather, it does record, but the recordings are blank). Everything's connected in the back as it was before, it's just happened in the last couple of days. Can someone help? thanks,
SOURCE: Faulty Panasonic DMR-E85H
You must replace the inside "str" sheet feeding and condenser close. Everything back to normal. :-)
Posted on Dec 06, 2007
Palmbeach
  • 185 Answers
SOURCE: PANASONIC DMR E85H
Yes you can.
You can get the instruction manual here:
http://service.us.panasonic.com/OPERMANPDF/DMRE85H.PDF
Posted on Feb 24, 2008
Palmbeach
  • 185 Answers
SOURCE: AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Posted on Mar 13, 2008
  • 4 Answers
SOURCE: panasonic DMR-ES10
Does the unit emit a groaning sound just before it fails? If so, then the drive spindle is the problem; the sound is caused by the slipping of the disk on the spindle. It could be contaminated with particles (dust, DDV plastic. etc). Look for scratches on the inner ring area of the bottom side of the DVD. those are an indication of foreign material on the spindle. It may be worse with disks that have been used many times. Just touching the hub area with your fingers can leave contaminates. Try first cleaning the disk hub area on the botton side. Stay away from the writable area. The drive spindle can be cleaned by removing the metal top from the unit and then removing the black plastic cover from the drive top (4 screws). Wipe clean the rubber surface on the top side of the spindle. Then replace the covers. As the unit ages, the rubber will get harder and more prone to slipping. A cotton cloth soaked in alcohol may be used to clean and refresh the rubber surface as a last resort. Reply to this message if you want pictures of the process.
Posted on Aug 01, 2008
SOURCE: PANASONIC DVD RECORDER DMR-E85HP
My Panasonic DMR-E85H also had the frozen "Please Wait" problem.I found this site and followed the instructions regarding replacement of the C1270 and C1271 capacitors with Radio Shack 1000uF 35V radial-lead capacitors (model 272-1032) @ $1.59 each. Took about 30 minutes plus the time to get the parts. Keep in mind that my husband and I have never done anything like this before. We followed all the posted instructions and the our Panasonic DMR-E85H works great now. Many thanks to everyone who posted these solutions and especially RandyChev for the great pictures. - What a life saver.
Posted on Jun 20, 2009
My Panasonic DMR-EH55 has suddenly stopped outputting. Regardless of whether I am using the HDMI or component outputs, my Sony tv indicates "no signal". What kind of problem am I looking at?
Try it with another TV, perhaps a friend's or neighbour's. If the problem persists, consult your local Pana service centre or a competent technician
Sep 25, 2013 | Panasonic DMR-EH55 DVD Recorder/HDD...
When we put an SD card in, onTV we get 3" grey
This is a tv setting problem, not a camera problem. If you have a widescreen tv, it can be set to several width aspects. Check your tv manual for instructions.
Sep 27, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
Mar 01, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
Everything has been working perfectly for 3 years or so/ done nothing different,use almost exclusively the HDD on my DMR-EH60, then suddenly the TV no longer responds to my commands. Unit goes off and on...
The DMR-EH60 has been working fine for a good five years then it started intermittedly loosing sound when using it as tuner for our display panel. Now there is not sound at all even recordings from TV onto the HDD. Any ideas?
Jul 19, 2009 | Panasonic DMR-EH60 DVD Recorder/HDD...
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Panasonic DMR E55 DVD Recorder
Hi James,
When in EXT link mode the recorder is looking for a signal from the TV to start recording off the TV's timers system.
There is a EXT Link button on the remote control and pressing that will take the machine back to normal mode. The button is near the bottom of the remote.
Hope this helps
Andy
Sep 09, 2008 | Panasonic DMR-ES10 DVD Recorder
DMR-EH75V DVD Recorder
ekimt,
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
mjs8
Aug 04, 2008 | Panasonic Diga DMR-EH75V DVD...
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
PANASONIC DMR E85H dont startup
I was playing dvd and it just stopped and message came on saying ( please wait) It still has dvd in and cannot get it to do anything
Feb 05, 2008 | Panasonic DMR-E85H DVD Recorder
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
