Question about HP OfficeJet 7110 All-In-One Thermal Printer
Hp printer 7110
I am trying to copy a document but it keeps saying supply expired and replace black ink cartridge when I just did.(?)
  • brendasbread Aug 04, 2008
    When I try to print, it will show expired color, even though it has been replaced. I have taken all measures to make sure everything has been cleaned according to the manual. Can the color cartridge be turned off when I want to do so.
  • jamaln Nov 12, 2008
    I have HP 7110 ink 90% full but expired what I can do?
    Novelist:
  • 106 Answers
Try to remove the black ink cartridge. From there, you can check the expiry date of the Ink cartridge. If its already expired, then you need to use another black ink cartridge that is not yet expired.
Thank you so much.
adonscott
Posted on Jul 10, 2008
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Printing off computer
Most likely your new cartridge has a damaged head. The tiny bit of electronics could have a fault, and therefore not be read properly by the printer. Try taking the cartridge out and cleaning the head with rubbing alcohol - both on the cartridge and the printer - then put it back in. If that doesn't work, try a different cartridge.
Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
How to use ink I have purchased?
i don't know what printer do you have, but HP print cartridges are resetable, just find it on google, type your printer type and reset cartridge
Jul 10, 2009 | HP Office Equipment & Supplies
Reset HP 7110 to factory settings
usually setting your computer to a date before the expiration date of the cartridge. If your printer has a date function try this first on your printer.
Jun 27, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Aug 04, 2008 | HP OfficeJet D125xi InkJet Printer
7110 supply expired
According to posts on a another forum, you can fix this problem by unplugging the printer, removing the battery or sticking a business card between the battery and its contact point. It should work when you plug it back in.
Jun 15, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Supply Expired!
Reset the printer to the factory default setting that should resolve the issue, you can provide me the make and the model so i can give you the instructions how to set the printer to default factory settings.
May 23, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Hp Officejet 7110 Not Printing From Computer
HP 7110 Printer
The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
Supply expired
So many models. Does this model have printheads under the ink carts? If so, remove the print head and clean the jets with a damp Bounty paper towel. Fold the towel up a few times and blot the head into it a few times to clean out the dries ink.
Aug 09, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 7110 battery and cmos location
The battery is located behind the left front cover. Open the printer, grasp the left front cover from inside the printer and pull to open. Look inside the printer to left and you will see it.
It is enough to remove for a minute to reset the expiration.
But I'm afraid after that the printer may not keep the date and time when turn off.
Jun 19, 2007 | HP OfficeJet 7110 All-In-One Thermal...
HP OfficeJet 7110 All-In-One Thermal Printer Logo
386 people viewed this question
Ben Johnson
