Question about Samsung CLP-510 Laser Printer
Printer has worked perfectly for several years, but is now not printing on the left part of the page.
  • jpgraf Nov 14, 2010
    Works fine after cleaning drum. Thank you
  • Samsung Master
  • 4,737 Answers
Have you tried with another Drum? This must be a bad drum issue. I think the problem is not different with color printing or black printing, or is it? First of all, clean the drum unit with a soft feather and if possible, disassemble the drum and remove the wasted toner. If this doesn't helpful, you'll need to try with another working drum or if needed, you better replace it.
Let me know with more details if this doesn't help. Thanks.
Posted on Nov 14, 2010
Printer prints off the side of the page
Hp2600n Colour Printer Colou Problms
Feb 14, 2014 | Lexmark E332n Laser Printer
Prints some blank pages
Hello Mike,
Please try to refill the catridge and if it dint help you then replace the Catridge ,which will surely pay off you..Thank you...
Please Post on how things turned or for further assistance..!!
Regards!!...
Jul 24, 2008 | Canon SmartBase MP730 All-In-One InkJet...
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
My Lexmark x125 all in one only prints blank pages
configure the proper port for the printer if you using usb cable for printer select the usb port in the properties of the printer ......
check the port you configure to printer
Oct 06, 2009 | Office Equipment & Supplies
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
Epson Photo Stylus 950 not functioning
when ever you want to refill ink make sure, that the ink you refill decompressed for about 30min before you fix it into the printer.
Another thing is that you uninstall the software of the printer and reinstall again, and check the power supply of the printer is working perfectly.
Dec 03, 2008 | Epson RX620 All-In-One InkJet Photo...
Printing on the same line after a few pages printed
I first oiled the bar once more and while the printer was off, moved the head across the bar forcefully several times until it felt the ease to move. I then typed a document with numbers 1 to 10 each number typed two lines below the other and tried printing this document several times. This worked perfectly and the printer is now in order.
May 30, 2008 | Epson LX-300+ II Matrix Printer
HP Business Inkjet 1000 error detecting new cartridge
Disconnect the communication cable (USB?).
Turn off the printer, wait one minute then turn it back on,
Then press the left button on the panel, the transparent one to the left of power button. It will print a status page. Check the dates and information under each color that is failing.
The ink cartridges MAY be outdated. Printing the test and information page without the computer connected fools the machine since it can't get your computer date.
If the cartridges are outdated, then change your computer year back to 2005 or so, reconnect the printer cable and send something to print, once the printer prints it out, reset your computer to today's year.
You will need to do this procedure whenever you turns off the printer. (Disconnect cable, change computer year, print, reset computer date).
Hope this works.
Wagner
Feb 20, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Samsung CLP-510 Laser Printer Logo
218 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
