Question about HP Designjet Z6100ps InkJet Printer
Directions to load paper into hp design jet z6100 ps
  • 58 Answers
SOURCE: hp p1006 wont load/feed paper
Mine does the same thing. The solution I have used on several occasions is to load it as full of paper as possible without forcing it under the guides. Lift the lid to reset the jam function, then when it begins to try to print, push the top one or two sheets of paper into the printer. If it will grab them and print then it will be ok for the whole stack of paper. Adding more paper before it gets too low also seems to help.
Posted on Jun 05, 2009
  • 1121 Answers
SOURCE: HP Design Jet 755CM will no longer print on photopaper
check the correct drivers, and paper sensor on the machine
Posted on Oct 31, 2009
  • 217 Answers
SOURCE: hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Posted on Jul 29, 2010
  • 54 Answers
SOURCE: When I power on my
these can be tricky. The paper has to line up with that line on the right hand side while the machine pulls it backwards and forwards. Try again.
Posted on Feb 11, 2011
  • 6 Answers
SOURCE: Maintenance cartridge is Missing on
in the cartrige there is a white stik about 10x30mm .If there is an ink on it the Plotter can't detect the cartridge..So just wipe out the ink on it an everything should be fine.
Posted on Aug 19, 2011
Z6100 banding verticle in black
When you banding vertical do you mean Across paper feed direction OR With paper feed direction?
If its across the feed direction the chances are thje issue remains with the individual printhead, Print out a quality maintenance print to find which Printhead is not working as well as wanted, then replace ( or clean using the plotters control panel under image maintenance.
Errors along the feed direction can be down to Software/ Main Pca /
Mar 11, 2014 | HP DesignJet Z6100 Wide Format InkJet...
Hp dj z6100 banding using lexjet ink photo black only
could be the non-HP ink has clogged up the printhead. You should try a new printhead and see if that solves the problem. (I bet it returns if you keep using the lexjet ink)
Mar 05, 2013 | HP Designjet Z6100 InkJet Printer
I have a hp z6100 and it keeps saying load roller
Do you mean load up Take up Reel, in which case the Take up reel option can be switched off in the paper menu accessible from the front panel on the Z6100.
Feb 22, 2013 | HP Designjet Z6100 InkJet Printer
I consistently get a "Paper Skewed" message on
It's just a practice with every plotter that i've worked on.The guide lines are absolutely inacurate.For every individial z6100 may be different but in mine the the right side of the paper must be about 3mm inside from the tip of the guide arrows(the paper must cover 3mm of the arrows).
Jul 12, 2011 | HP Designjet Z6100 InkJet Printer
Maintenance cartridge is Missing on a hp design jet z6100
Jul 06, 2011 | HP Designjet Z6100 InkJet Printer
I have a z6100 designjet printer. I often print direct from Acrobat using the HPGL2 driver. The problem I have is: I rarely am given the option to delete the custom paper sizes that I have created. The...
just use your custom paper size and rewrite the settings.In some drivers U cannot delete the paper size from the driver properties.IF U still want to delete the custom paper size that you've created They are in the windows registry_but deleting keys from there is not recommended.
May 09, 2011 | HP Designjet Z6100 InkJet Printer
We spend a large portion of our day desperately trying to load paper and always getting the "paper loaded with too much skew" message. The paper is straight and on the blue line, i'd love to trun...
What type of paper are you using? It's common on cheap canvas or fabrics. Make sure the beginning of the roll about 10 inches must be straight in right side (blue line side). The paper slips upward freely and straight before lowering blue lever. Also this problem appears when your room is dry (low moisture) then PP sticker and some photo paper will curl. This checking feature is very useful for printing on whole roll in a single feed.
Mar 22, 2011 | HP Designjet Z6100 InkJet Printer
I have hp designjet z6100, when turn power on it gives empty box on display, and nothing else.
Hi so no error code? I'm sorry to say without an error code to point to the fault is not not going to be a simple job,
I make a living repairing designjets but I'm not supported by Hp, my best advise would be to email Hp and ask for a Maine agent in your area then pin them down to a price to come out and give you a quotation for the repair on your plotter
Yours Ian
Ps if this has been useful please rate me
Mar 10, 2011 | HP Designjet Z6100 InkJet Printer
Oct 31, 2009 | HP DesignJet 755cm InkJet Printer
HP Designjet Z6100ps InkJet Printer Logo
249 people viewed this question
Seeker5211
Seeker5211
