Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Scanner Lamp Replacement?
Is there a replacement part for the lamp itself for this machine? When scanning/copying/faxing, the result is a page almost completely black, and the lamp is VERY dim durring this process.
Thanks!
  • 1 more comment
  • golfer123 Jul 04, 2008
    I've had mine 7170 awhile and now the light source is orange! I can't seem to locate a replacement. Any ideas??
  • msbama40 Feb 24, 2009
    I have the x7170 also and the light went completely out. I called Lexmark and they said that it cannot be replaced, but they did offer me a 20% discount to buy a new printer.
  • Anonymous Mar 06, 2009
    my light went to a bairly lit pink color and the faxes dont come out. I got an HP Officejet J6480 from TigerDirect for $99 it is AWESOME and it is WIRELESS, no more printer cable and I can print from any PC on my network..
5 Suggested Answers
  • 31 Answers
SOURCE: Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Posted on Jun 25, 2007
map9966
  • 2351 Answers
SOURCE: Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Posted on Apr 25, 2008
s4u311
  • 813 Answers
SOURCE: What's wrong with X7170 copy/scan functions?
ya u need to change your blub
Posted on May 11, 2008
Ajkill
  • 2035 Answers
SOURCE: two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Posted on Nov 11, 2008
  • 33 Answers
SOURCE: Lexmark 8300 print/scan/fax
There are sensors in the document feeder that detect the width and length of the paper being copied or faxed. Try getting a can of compressed air and go nuts blowing all the dust out of the feeder, if you spray everything you can get to, you will probably blow clean the sensors. Just an educated guess.
Good luck,
Printdoctor
Posted on Jan 04, 2009
If copy quality is very dark then what to do for making it normal
The dark quality is definitely linked to a light intensity problem. If the scanner lamp is operating properly then check for any reflective surfaces near the scanning lamp and clean those. It only takes a light film of dust to make copies dark. Be careful around the lamp, it is delicate.
Jan 26, 2015 | Canon 2234B007 - Faxphone, L90 Laser,...
Blank copies from copier
You don't say what model your fax is.
In general. If when copying you get a Full BLACK page printed then the scanner lamp is not lit. As no light is reflected into the image scanner, it interprets this as BLACK information so therefore only black is printed. Look into the ADF while the document is being scanned and I bet you will see no green light at all. A new Contact image sensor should cure it.
Jan 13, 2014 | Canon Duplex Automatic Document Feeder
Black pages
If everything is coming out Black it sounds like the lamp in the scanner has gone bad. If you can get the part from sharp it might not be hard to replace, but the cost may out weigh the cost of a replacement.
May 14, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Copys and sent fax are showing black pages, but when receiving fax it prints out fine.
Your scanner lamp is not coming on. Could be the lamp or driver board. Either way it is cheaper to buy a new fax.
Oct 21, 2009 | Brother Office Equipment & Supplies
When trasmitting the receiver copy is totally dark
The exposure lamp is not coming on, try unplugging the machine for a few minutes. power it back up, Try making a copy, it uses the same parts as out going fax.
If that doesn't work, feed a page into the fax, press copy, if you look where the original comes out you should see a bright light, this illuminates the original so the scanner can see the page. If that lamp is not coming on the lamp or the control board for the lamp has likely failed.
Hope this is of some help.
Ed
Apr 26, 2009 | Office Equipment & Supplies
Black pages on every fax I send
Is sounds like your exposure lamp is not coming on, put an original in the machine and make a copy, if you look where the original is coming out, you should be able to see a light illuminatig the original so the scanner can read the image. If this lamp is not coming on you will get a very dark to black image.
If it is just locked up is may be as easy as this. Turn off and unplug the machine for a couple of minutes, reconnect and power up the machine, make a copy. as the machins uses the same parts to copy you should see the result of your efforts.
If the copy look good, try a test fax to someone, and call them for confirmation.
If this doesn't fix the problem, then I suspect the exposure lamp unit has failed.
Apr 17, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Fax Problem KX-FL541
your scaner is dirty,you have maybe nsome stuck in the scanner,or correcton fluid gooes from document to scanner lamp,check is all ok ,if everythin clean,your scaner lamp has a damaged ,try to change it or call service man
Feb 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
392 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
