Question about Olympus Cameras
Olympus FE-47/X-43 is reading low battery or empty battery with new batteries inserted.
dlundmark
  • 797 Answers
SOURCE: hi, my olympus digital camera FE-310 (1,6 years
Make sure you have the right kind of batteries. These kinds of cameras can use the batteries very fast if they are not the correct kind recommended by the user manual. Read the user manual.
If the camera works correctly, and takes pictures and movies okay, and still uses batteries quickly, then more than likely, the batteries must be the wrong kind. Never use the cheapest kind of double-A in these cameras.
If you use rechargeable batteries, make sure they are charged fully before using the camera.
Try this: Turn the camera on, make sure that the menu setting for the kind of batteries you have installed is set correctly. If you set the wrong kind of batteries, the problems you are having is a common thing.
Also turn the camera on, then set all the menus to the default settings. Then make sure that the kind of batteries you are using is set in the menu as (if alkaline set it so... If rechargeable, set so ... other options may exist in menus).
Posted on Oct 23, 2009
SOURCE: olympus fe 130
i have always used duracell batterys in this camera and it workd untill today. now it is giving me the battery empty error even when they are brand new and correctly installed.
Posted on May 08, 2008
SOURCE: Olympus camera: battery empty
Try reading page 54 of the manual. If you don't have it still, go to their website.
Posted on Aug 14, 2008
  • 11967 Answers
SOURCE: Olympus FE-280 8 megapixel Lens won't open.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 18, 2010
SOURCE: Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Posted on Jan 20, 2010
Keep saying battery empty evn whn i just charged them
Some rechargeable batteries (NiCd and older NiMh) have a (bad) memory.
If they have, the charger cannot fully charge the batteries to their original
potential capacity.
Best thing to do is to buy new rechargeable batteries and a processor
controlled charger to prevent premature malfunction of your batteries.
There are new type precharged batteries which have a very low discharge
over time. Like the Sanyo Eneloop and such!
Jul 15, 2011 | Olympus FE-310 Digital Camera
"Battery Empty" Message
extra dose 12V power pinch for 3 sec
Jun 18, 2009 | Olympus FE-20 Digital Camera
Camera won't work even with new batteries
Just had that same thing happen.
Try lithium batteries...Should solve it.
Jun 14, 2009 | Olympus FE-210 Digital Camera
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Every time I insert new batterys but display shows low battery
try to reset your camera and be sure that your battery is fully charged just like a new one.
thank you for using fixya
CHARCOIS
Jan 20, 2009 | Olympus FE-170 Digital Camera
Olympus FE170 digital camera shows battery compartment empty with batteries in place I have the same problem. When I place fully recharged batteries in the Olympus FE 170, the camera won't power on at...
on rechargeable batteries, check the mAh on the side, you would need to be about 2300 or more. also the shelf life on some rechargeables may be less than desireable... try lithium digital
Dec 16, 2008 | Olympus FE-170 Digital Camera
Battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Nov 24, 2008 | Olympus FE-230 Digital Camera
OK, here's the answer. You won't find it anywhere else, but here it is.
If you use rechargable batteries, you MUST use ones with a respectable capacity. 2000mah are probably not enough. You need 2400mah at least. Yes, it doesn't make much sense, in the the battery capacity is supposed to reflect how long they'll last. But the wimpy batteries just won't let this camera turn on.
I have some experience with different battery capacity in this camera, and it took some aggravation to figure this out. But I'm pretty sure this is the answer.
The higher capacity batteries are more expensive, and their hold time is probably not as good. But I get a reasonable amount of usage with them.
Jul 20, 2008 | Olympus FE-210 Digital Camera
Olympus fe 130
Ive had the same problem with my camera and found that it was the quality of the batterys. you have to use good quality high drain batterys for digital cameras.
Nov 02, 2007 | Olympus FE-170 Digital Camera
Cameras Logo
931 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
