Question about ASUS K8S-MX Motherboard
I've AMD Athlon 64 bit processor 2800+ Motherboard Asus K8S-MX Series SiS 760 Fx series chipset BIOS version: 08.00.11 How can I save my current bios and update bios??
    President:
  • 1,812 Answers
You must plug in your pc with ups
do step by step from internet and alwayas choice last date
http://support.asus.com/technicaldocuments/technicaldocuments_content.aspx?no=714
for download =http://drivers.softpedia.com/progDownload/Asus-K8S-MX-Bios-1013-Download-13287.html
1st thing you'll need to do is go to the motherboard manufacturer's website & download the new BIOS file & the flashing program. These 2 files will have to be copied to a bootable floppy, then you'll have to boot off it & do the update from DOS. The motherboard website should have a detailed explanation on how to perform a flash...print out the instructions & follow them exactly & you should have no problem
Posted on Nov 12, 2010
What can i use processor in this motherboard can i use 1.8 mhz
Processor speed 1.8 MHz is not the parameter for using this kind of motherboard. Upgrading or replacing CPU on motherboard is based on the socket CPU, and your motherboad support AMD® Socket AM2 Athlon 64 X2 / Athlon 64 FX / Athlon 64/ Sempron....
Aug 06, 2011 | ASUS M2N-MX Motherboard
Support processor for upgrade to higher processor
This are the comptible processor that you can use for this motherboard if you plan to do a upgrade on it. AMD Athlon 64, AMD Sempron, AMD Athlon 64 FX, AMD Athlon 64 X2
Here is a link that contain all the details about this motherboard.
http://www.dealtime.com/xPF-ASUS-Asus-M2N-MX
Aug 04, 2010 | ASUS M2N-MX Motherboard
How high cpu can i use in k8s-mx
Compatible Processors are AMD Athlon 64, AMD Sempron
with a Front Side Bus Speed 800 MHz
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
May 17, 2010 | ASUS K8S-MX Motherboard
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
The best sistem for k8v-mx
Supports AMD Socket 754 Athlon 64/ Sempron processors, here is a list of processors supported by the motherboard >>>>
http://www.cpu-upgrade.com/mb-ASUS/K8V-MX.html
As for the graphics, the board supports PCI Express graphics cards, its up to you which card to buy, you can either purchase Nvidia Geforce 9 series or ATI Radeon HD series.
Regards.
Aug 01, 2009 | ASUS K8V-MX Motherboard
Error takes place whenever i install the driver of the motherboard Asus x series K8S-MX socket754 sis760gx fsb800 vga integrated Agp8x
what kind of error
try flashing the bios but before you do i need to know what kind of error you are having. it could be a bad disc try putting the driver on a flashdrive downloaded from ASUS first then flash the BIOS if all else fails.
May 06, 2009 | ASUS K8S-MX SiS 760GX Socket 754 DDR ATX...
Asus k8s mx mother board problem
To get rid of this message at boot you must turn off the Chassis Intrusion detector feature. To do this you must restart the computer, as it boots press DEL to enter BIOS.
Under the SECURITY tab in BIOS select CHASSIS INTRUSION and select DISABLE.
Then select EXIT and SAVE CHANGES and OK to reboot the system.
Jan 31, 2009 | ASUS K8S-MX Motherboard
DDR2 with ASUS A8V-MX motherboard
This motherboard supports AMD 939 pin Athlon 64 FX/ Athlon 64 processors with 1MB, 512 KB L2 cache which is based on 64 bit architecture. It features 1600 MT/s HyperTransport Bus, dual-channel unbuffered DDR400 memory support and AMD cooling Technology. So you should be able to use the RAM as long as it falls into the above specs. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | ASUS A8V-MX Motherboard
ASUS K8S-MX Motherboard Logo
273 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
