Question about Zanussi 29 in. LS14 Free-standing Dishwasher
I open the door after start the program then i close it .but it didn't work again electricity lump is on
  • 10 Answers
Inside the door(hood) is a magnet(grey)
This magnet activates the magnetic switsh inside the dishwasher.
The problem is that the magnet is broken or out of it position.
kostas
Posted on Feb 11, 2011
Reset key fob
Unlock all doors, foot on brake, all doors closed. Cycle key quickly but carefully on-off appr 10 times until the car honks one time.
Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up.
When the horn honks, open and close the driver's door, press any remote button and that's it.
Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it.
When you're done, remove the key and the horn should honk 3 times. You're all set.
Sometime it takes more than 10 on-offs to set program mode. Open/close the door, lock/unlock etc, wait 10 minutes, then try again
Jul 22, 2014 | Subaru Outback Cars & Trucks
Maytag fridge right door won't stay closed
it may be necessary to reset the hinge adjustment to move the door further across the opening giving the magnets a better area to hold on to . there is a slight amount of adjustment in the mounting points of the hinges. You may have to replace the door gaskets as they become hard over time and the magnets cannot work properly in the hard plastic
Jun 21, 2013 | Refrigerators
I replaced the battery in my key fob and now the remote start will not work it pops the trunk open. How do i get the remote start to work again?
If it pops the trunk then the unit is still programmed correctly to the vehicle. I would open it and check the buttons and ensure you didn't pinch them and they are still making contact with the pads inside key fob. Probably just stuck after closing the remote.
Nov 11, 2011 | 2006 Chevrolet Impala
Programming instructions for keyless remote Does anyone have the programming instructions for 1998 honda passport keyless remote (FCC #HYQ1512R)?
Get into your passport and unlock all doors. Leave drivers door open. Put key into ignition. Turn to ON (not start), then OFF three times within 5 seconds. Close and open the drivers door twice. Turn key to ON then OFF 5 times within 5 seconds. Close then open the drivers door. Press either the lock or unlock button on the remote. Doors will lock then unlock. Press the button again. Doors will lock then unlock again. Close door to finish programming. If it doesnt work, try it again but turn the key faster. You have to do it all pretty quick, but I had it done on the second try.
Oct 03, 2009 | 1998 Honda Passport
2006 Criuser won't start and intrusion alarm can't be stopped
YOUR WIRELESS CONTROL MODULE(SENTRY KEY MODULE)MAY BE ELECTRICALLY LOCKED UP..THERE IS A SERVICE BULLETIN FROM CHRYSLER..YOU CAN REMOVE IOD FUSE IN FUSEBLOCK(UNDERHOOD BEHIND AIR CLEANER..IGNITION OFF DRAW(IOD)THIS WILL RESET WIRELESS CONTROL MODULE AND VEHICLE SHOULD START AND LOCKS RESPOND AGAIN..IF IT DOES,THE WCM WILL HAVE TO BE REPLACED AND THIS NEEDS TO BE DONE BY DEALER
May 30, 2009 | 2006 Chrysler PT Cruiser
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Jun 07, 2008 | Zanussi FJS1225W Front Load Washer
Door hard to close have starts to close stops and starts to open again have to keep stopping and reversing door mult times to get closed
There should be two small white adjustment knobs on the side of the unit that you turn with a small flathead screwdriver. These are the load / limit adjusters.
What it happening is it think there is something stuck under the door (like a car hood, etc)
These adjustments are VERY sensitive, so be patient while adjusting them.
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Zanussi 29 in. LS14 Free-standing Dishwasher Logo
78 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
