Question about ASUS A9RP Notebook
When i plug the charger in the first time it is working but when the charger is unplug the laptop is not working.
    Novelist:
  • 107 Answers
Hi Tim, As per my understanding you are experiencing issues with the laptop not working without a charger being plugged in.In this regards what I would suggest you do is see if the battery charges with the charger plugged in and in case the battery does get charged see if you are able to power on the laptop with just the battery connected and no charger plugged in.If you are able to get the laptop to turn on only with the charger connected and unable to power on with just the battery then it would be an issue with the battery not getting charge.So before you replace the battery please unplug all external devices from the laptop including the charger and the battery and without the charger or battery connected to the laptop please press and hold down the power button for 30 seconds after which please insert the battery into the laptop and see if you are able to turn on the laptop.This step is performed so that we could drain out unwanted static electric charges from the laptop.In case this step does not work please do consider replacing the battery since it would be an issue with the battery not getting charged. Best wishes for your effort.
Posted on Nov 12, 2010
2 Suggested Answers
  • 11 Answers
SOURCE: Hey, I have an Acer Aspire 3624WXCi. in the fall
Your battery is not holding any charge it is your battery you need to get another battery from acer.
Posted on Mar 01, 2011
Not startup when power button pressed
have you tried pressing the start button for 10 secs with battery and charger unplugged?
Jan 10, 2014 | Computers & Internet
My Acer Aspire won't recognize the battery charger. I plug it in and nothing happens. After I unplug and re-plug it back in several times, sometimes my computer will recognize it and will start to...
Try wiggling the plug around a bit to see if you can get contact. You could also try borrowing a power supply if you know someone with the same machine to isolate the problem.
Oct 16, 2013 | Lifetime Acer Aspire 4810TZ-4011...
Laptop shuts off when unplugged
its one of three thing charger battery or d/c jack (the bit you plug the charger into on the laptop) which needs replacing cheapest option try another charger they have a pin in the end of the charger witch connects to the DC adapter after time this pin can be moved if the two do not connect the laptop will not recognise the charger as genuine and will refuse to charge the battery
Feb 10, 2012 | HP Pavilion dv7-1130us laptop
Targus Charger Problems
It looks like there is a shorting taking place whenever you insert the power jack into the laptop. Most likely the shorting is taking place on the laptop side and requires replacement, which should be done at the manufacturers service station even if its warranty has expired.
Dec 02, 2011 | Targus Computers & Internet
My laptop suddenly switched off while i was checking my email. The charger was pugge in at the time. I tried to restart the laptop but it refuses to start.
Un-plug unit...take battery out of unit... plug in the power cord and see if it starts up... bad battery
ask me another question...
Nov 25, 2010 | Toshiba Computers & Internet
Laptop mouse pad doesnt work if being used on flat surface
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 27, 2009 | HP Compaq nc6320 Notebook
Dell laptop charger
If the charger is older and since you saw the light go on then off again, it could just be the charger wires. Assuming your charger has a black box attached to it, try pushing the cord in towards the black box (usually the end leading to your laptop) . If that doesn't work, wiggle the cord in that area. If this works, your problem is simply the wire is worn out. You can fix it by exposing the inside wire where the bad connection is, snip it, reconnect and cover with electrical tape. I just did this to my sister's last week.
Aug 22, 2008 | Dell Inspiron 6400 Notebook
Dell laptop charger
First try starting the machine without the battery, only the charger, Then check the charger with an ohm meter to see if it's working properly. The out put readings are listed on the charger. In case of a surge, the charger is designed to go out first before damaging the system. However, this is not always the case. If the charger checks good, then you should take it in for a professional diagnostic because the problem may be with the power management system on the motherboard. One thing to keep in mind for future reference is when moving to a different location with your laptop, when unplugging the charger, always unplug the charger from the laptop before unplugging from the wall socket, and when plugging in, always plug the charger into the wall socket before plugging into the laptop. This will keep from surging your system.
Jul 16, 2008 | Toshiba Satellite A45-S250 Notebook
ASUS A9RP Notebook Logo
306 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
