Question about Linksys Wireless-G WRT54GX Router
Blackberry connection problems
My new blackberry 8320 connects at other wireless locations but not at home using my Linksys WRT54GX router. After I enter my WEP key and try to connect I get connection error code on the blackberry. Is there a firmware upgrade or adjustment that will fix the problem?....Steve
  • pink_muimui May 11, 2010
    If the router's security is disabled, can you connect with your blackberry with no error messages?
  • 1,940 Answers
You can find and download your firmware update from Linksys by clicking here
Posted on Jul 14, 2010
I have a Linksys WRT160Nv3 wireless router and a blackberry curve 8900. My blackberry tells me that it will generate a PIN, which I will then enter somehow into the router to satisfy its WEP security...
it wont, Mobile devices do not have the option to have a generated pin the same as for a Router vice versa, the only you can get connected to your router from your blackberry is to have your router security key disabled. this will allow you to connect any mobile device on your router, a PSP and other wireless devices than can use wireless internet.
Jun 07, 2010 | Linksys Computers & Internet
BlackBerry Curve 8320 will not connect with HS-100W
If it's any consolation. My BB 8820 connects to my Zyxel NBG-460N, but after a few minutes the connection just dies (the BB still shows its connected to the WiFi, tries to use it and can in fact send packets out, but it does not receive anything any more). The router has gone through 3 firmware upgrades so far and no solution. It's also causing trouble with some USB WiFi sticks when the SSID hiding is enabled.
In short: I believe ZyXEL's WLAN support is simply broken, and you'll have to buy a WLAN AP from another manufacturer.
Oct 04, 2009 | Zyxel HomeSafe HS-100W Wireless Router...
Wireless Networking With a Linksys Wireless-G WRT54GX Router?
k2rt9ceswg,
You seem rather savvy so I won't bore you with frivolous explanation. Essentially ISPs detect the MAC address of whatever device is plugged into their network. In the case of your laptop connected wired to your modem, the MAC address of your wired adapter is what is tied to your ISP account. When you plugged in a router, the MAC address of that router was different than your laptop's wired network adapter and your ISP said "nope, not letting that connect". This is something most ISPs are doing now-a-days.
You can get around this by following these steps:
  1. Plug your PC back into the modem wired
  2. Ensure you have internet connection again
  3. Go to Start -> run and type "cmd" without quotes
  4. Type "ipconfig /release" without the quotes (there is a space in there that needs to be in there)
  5. Disconnect your PC from the modem and plug the router into it
  6. Plug another LAN cable into the router and your laptop
  7. In the same command prompt, type "ipconfig /renew"
If the computer pulls an IP address for the wired ethernet, you should be all set to disconnect the cable from the router and PC and try to connect to it wireless. If it doesn't pull an IP address, you'll need to contact your ISP and inform them that you're having trouble getting your new router to work with your existing network.
You might also consider depressing the reset button located on the back of your Linksys router to set the router to its default configuration. This would clear all previous settings if there were any and might clear up any configuration options you had set when previously using this router.
Mar 03, 2009 | Linksys Wireless-G WRT54GX Router...
Setting linksys WRT54GX Ver2 with D-Link DSL-2450T ADSL2+router
Your router needs to be configured. Call Linksys Technical Support. If they cannot help you try this http://technicalsupport.blog.friendster.com
Feb 15, 2009 | Linksys Wireless-G WRT54GX Router...
Can't connect my Ipod touch to my router?
You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this http://technicalsupport.blog.friendster.com
Feb 08, 2009 | Linksys Wireless-G WRT54G Router
Blackberry Curve 8320 ?
no browsing the web will not affect your mins only if you are making calls....you can only use a wireless router with your phone once the phone is wifi enable.
Jan 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Can't connect Blackberry Curve 8320 to 2wire wifi
W002 - Wi-Fi Connection Failed
Means The phone cannot get an IP Address from the Server.
Common issues are
The signal is to weak to make a reliable connection
WEP is configured incorrectly or WPA
DHCP may be disabled, it needs to be enabled on the router
There are other more technical issues to this but without more information this should be a good start.
Dec 25, 2008 | RIM BlackBerry Pearl 8100
Cannot get Blackberry pearl on internet
Had same issue with a BlackBerry 8320. Disabling the 22MBps on the DI-614+ fixed the problem (in performance, advanced tab, select 1-2-5.5-11 MBps for TX and Basic rates).
Jun 15, 2008 | D-Link AirPlus DI-614+ Wireless Router
Linksys Wireless-G WRT54GX Router Logo
187 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
