Question about Hoover Washing Machines
Error code E11 on hoover washer dryer vhw854d
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Posted on Dec 23, 2010
  • 2 more comments
  • fussychef May 02, 2011
    Thanks for the info. I had this problem with my machine and my husband reattached the wire, which had clearly disconnected from the housing. He does have a degree in electrical engineering, but it was a pretty straight forward job with no call out fee and the machine has worked perfectly since.
  • Luca Gentile Apr 26, 2013
    here the picture of the disconnected cable
  • ralphberner May 07, 2013
    Great Post!! Thanks a lot. That was the cause for E11 on my machine too. Fixed it in less than an hour. Its worth to mention that the top cover can be shifted away after removing the three screws on the top rear side.
  • Leigh Sep 08, 2013
    As above, removed the 3 small bolts at the back under the lip and slid out the top panel. Removed the spade terminal that was broken and using some pliers managed to reattach to the terminal and refasten. BTW the cable did not need lengthening in mine.
I had the same problem but the wiring was completely cut off from the housing, it was impossible to repair it. The machine needed the wiring to be replaced
Posted on May 13, 2012
2 Suggested Answers
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Posted on Dec 20, 2010
What is error code F11 ?
An E11 error code indicated there's an open circuit on the dryer heater or a module issue it's a good idea to check the wiring from the sensor on the top the drum to the circuit board as this can become damaged during the spin cycle.
Nov 24, 2014 | Hoover Optima 7 OPH716DF White 600 mm...
I installed a new control panel in my Frigidaire dryer and it displays E11. Is there anything I can do to clear this code?
Hi Steve, thank you for your question!
Generally, error code E11 means that it has detected an internal checksum error or processor error. First check to see if it is a false error code by resetting the power to your dryer by either unplugging it or flipping the household circuit breaker for about 30 seconds. If the error code persists, your dryer may have a faulty main control board. Regrettably, this is not a simple DIY job. It is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Best of luck!
Feb 02, 2014 | Frigidaire Dryers
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Display reads E11
E11 error code means that the dryer thermostat is faulty.
Apparently it overheats if you use it too much or the motor of the fan (blowing hot air in the tumble) got stuck.
Check it and keep us updated.
Apr 18, 2011 | Hoover Washing Machines
Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
Dec 20, 2010 | Washing Machines
My hoover washier dryer has stopped heating up. I works ok as a washing machine but the tumble dryier doesnt heat up. It is a hoover vhw654d washier dryier
on all dryers you have a hi and a low relay as well as the heater and in some you even have a run tstat check that you have continuity on each side of each of your relays as well as your heater any of these pieces that does not have continuity would be the one that u wuld replace hope this helps if you are not electrically inclined plz call a technician
Jul 21, 2010 | Hoover Dryers
I have a Hoover vhd sensor Dry Washer Dryer and its come up with error E11. Can you help ?
Hi I had the same problem about once a week and every time it happened I had to turn off the washer off and leave for a while and start new wash cycle. It worked for a while but eventually it started to throw E11 once I put it on (not the middle of cycle it used to do). I had to result to call the repair man. He checked all the hardware and nothing was wrong and re-install the program on the board and it stopped throwing errors. After 4 month of problem free period, it gave me E11 again today though..
Jun 23, 2010 | Washing Machines
My hoover washer dryer VHD is showing a fault E11 and the washing in the machine is still wet
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Apr 10, 2010 | Candy Washing Machines
Washing Machines Logo
10,707 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
