Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier weathermaker 8000 central air conditioner
Water is coming out the back-bottom area, although water is normally dripping out the tube and into the drainage. (I have to cut the tube to check if the water is coming out normally.)
    Novelist:
    Champion:
  • 230 Answers
It sounds like your drain line may be partially plugged. Some times a small insect will get in there and cause a partial obstruction. IF the line is clear and the water continues to drip over the sides then make sure the unit is balanced So that the water will flow to the drain and not out the back.
Posted on Jun 18, 2008
My Carrier Weathermaker 8000 is blowing air out of the air intake. Is there a fix?
Try turning breaker off and back on. Fan is running backwards. Any recent repairs?
Nov 05, 2016 | Carrier Heating & Cooling
The filter should slide out of a built in rack from the side of the furnace by the return inlet. It should have the size on it or you'll have to measure it. It may also be inside the bottom door. Pull the door up and out, the filter will be on one side or the other. Unless you have a special Hepa or electronic filtering system.
Dec 12, 2013 | Heating & Cooling
CARRIER WEATHERMAKER 8000.NOT SURE HOW OLD. HAVE POWER,FAN COMES ON,IGNITOR GLOWS,GAS VALVE OPENS,BLOWER RUNS,IGNITOR GOES OUT. CYCLES THREE TIMES LOCKS OUT. ANY IDEAS?
sounds like the roll out switch may be sensing a clog. here is a website that can explain things better, hope it helps Tim:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
Oct 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I'm in urgent need of a fan motor for a carrier weathermaker 8000. Any suggestions where I may find one in the Atlanta (ne) area?
do you have a johnstone supply they are the only company I know of that sells to public you could also bribe a heat and air guy
Sep 20, 2010 | Heating & Cooling
NO HEAT???? freezing
go to the furnace, there should be a service switch on the outside of the unit.  make sure the door is on good, does the blower motor come on?
Nov 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
I need to change the filter in my Carrier Weathermaker 8000. WHERE IS THE DOOR?
There is a filter on the bottom of the unit. You will either have to remove the bottom panel in the front. Or thereis a thin acess panel down in the front of the unit.
Oct 24, 2008 | Heating & Cooling
Carrier Weathermaker SX
If you are running it in the cooling function, your drain maybe backed up. Find your drain outside if you can and suck it with a shop vac.
Nov 25, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
383 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
