Question about Durabrand DVD-1002 DVD Player
Dvd video player
No power.
Which the value of de diode zw1 of dvd 1002 durabrand
Posted on Jun 18, 2008
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
I was using my dvd players component outs for a year but my hi def tv died so when I hooked up my old tv to the single video out I can't get any picture out of it. I think I need to get into dvd player set...
If its an old Sony dvd player then check Progressive Scan button at rear or some may have it on front to turn off to get composite video output (yellow video out)
And if it does not have any manual switch for progressive scan then turn off dvd player by pressing power button on its remote control, press 3, 6, 9 on dvd remote and press power to turn dvd player On.
That will turn off / disable progressive scan mode and you will get video output from yellow video out jack.
Jul 31, 2010 | Sony Televison & Video
UNABLE TO OPEN THE FILE UNDER POWER DVD 6
which file format you r trying to open in power dvd player.
powr dvd player doe not support all formats.
i will suggest you to download and use the vlc player,it almost supports all video formats
May 07, 2010 | CyberLink PowerDVD 6 Deluxe Full Version...
Compatible DVD decoder is not installed MY PC
Dear Sir,
Here is the solution.
To play DVD video you must have DVD decoder Codec.
So you can use power DVD softwares of VLC media players,these players decode the DVD video.If you had latest Power DVD software download and install it.Otherwise here is the link for free VLC media player Download
Download VLC player
otherwise download Trial version of Power DVD
Download Power DVD 9
If you find any difficulty leave a feedback,we will glad to assist you
good luck
Sep 09, 2009 | Intel Premier Resources 4-Channel 32-Bit...
I do not know how to hook up my goldstar to my TV. My daughter gave me the dvd/vhs that was hers. Are there instructions?
The power cord of the DVD to be connected to the power supply.
the audio cable goes from the audio pin from the DVD player to the TV audio pin.
The video cable goes from the video pin from the DVD player to the TV video pin.
Jul 05, 2009 | Goldstar GBV241 DVD Player/VCR
Liquid Video MVBG619 Car power Cord
Hi Lauri3 just wondering if you would have just 1 of the remote control units for this dvd player for sale. Please let me know.
Thanks
veryounique@hotmail.com
Aug 06, 2008 | Liquid Video MVBG619 Portable DVD Player
Samsung l300a dvd player - no video, only audio
Try to reset the player. Remove the DC power supply. Remove the battery. Leave it for 30 mins. Power on using the DC power supply without the battery.
Sep 21, 2007 | Samsung DVD-L300 Portable DVD Player
Durabrand DVD-1002 DVD Player Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
