Question about Whirlpool GU2400XTP Built-in Dishwasher
Where does the bumper part go on the rack for the whirlpool quiet wash plus, du8600xb-1 I am replacing the upper spray arm and for the life of me I can not figure out where the bumper goes...it is a small clip, probably 1 by 3 inches
aborcass
  • 2651 Answers
SOURCE: broken nozzle and upper spray arm
the spray arm just screws back on, unless of course its cracked in which case needs replacing( chances are since it fell off its cracked) heres the part num 154478202
Posted on Mar 15, 2008
reg501
  • 413 Answers
SOURCE: water not spraying hard enough
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Posted on Jun 08, 2008
SOURCE: I have a Frigidaire Ultra
I may have the answer. I had what sounded to be the same problem. I found the dishes were dirty after they were cleaned, but I found there may have been a big pot lid blocking the upper arm. I decided to run the machine again, and after a bit opened the dishwasher after to make sure it was not a problem with the arm. Sure enough, the arm wasn't moving. However, I found out on the Frigidaire webpage that some models have an alternating spray cycle, where only one arm spins at any given time. After reading this I checked again, and it had moved by that time. I checked a few times more to confirm this. So it ended up it was an arm blockage after all. Hope this helped...good luck.
www.frigidaire.com/support/FAQ-Dishwasher.asp#6
Posted on Dec 14, 2008
  • 111 Answers
SOURCE: upper spray arms not spraying water
It sounds like you have a model that has a pot washer cycle that blocks water flow to those arms. What cycles are on your keypad? Sounds like you have it set or single rack wash
Posted on Dec 18, 2008
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
Whirlpool dishwasher quiet partner lol is not cleaning dishes on top rack
could be a few things clean inside filters and screens listen to it does the wash motor during wash sound strong like it tossing water around in there open the door during the wash see if kicks some water out at you. If it sounds and seems like its working ok then some units have a rubber check valve little flapper in the tube that goes up the back wall to the upper spray arm i have seem break off and clog that tub not allowing any water to the upper spray arm.
Dec 24, 2016 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool gold dishwasher model Quiet Partner 3. The top rack is not cleaning the dishes very well. We live in the country and have hard water. I am wondering if there could be a buildup of some...
if it is just affecting the upper rack i doubt it is just a plugged spray arm (though i could be wrong). more likely than not you have a blockage on the intake of your spray pump motor. a series of bones, toothpicks, foreign material, etc could be blocking the entrance of the pump causing it to starve for water so to speak.
you will more than likely need to remove the lower rack and spray arm to be able to disassemble the strainer and gain access to the sump.
a complete model number would help bunches to.. alas
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Quiet partner 1 top rack does not get clean at all
I would suspect you have debris in the pump that is causing a pressure drop so the water is not spraying well in the upper arm.
Try this procedure to clean out the sump. Let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 24, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Top shelf dishes are not washed
possibly low water pressure...
racks might be in backwards if it's an older model with wheels on shelf system... rubber bumpers should face out...
could be a blockage in the upper sprayer arm... or the upper arm had come off and was remounted in a position that doesn't line up with the jet of water from below...
could be bad loading technique... sounds simple enough but you should never put large bowls or pots that lay horizontally on the lower rack because it really screws up the cleaning effectiveness. Large items should always go on the top rack or be washed by hand if they don't fit on the top rack.
Sep 02, 2009 | Whirlpool Dishwashers
Dishwaher does not clean, upper rack
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Mar 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
Feb 14, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool quiet wash plus
I assume you are having spray issues, or a grinding noise. If odor is your issue, go to the bottom of the message.
For the dishwasher pictured above, Open the door. Remove the lower rack.
Push in the tabs holding the upper basket rail end caps and slide the caps up and out. Remove the upper rack. Clean the holes in the upper (or middle) spray arm.
Hold the lower spray arm still and rotote the thumb tab clockwise. Remove the lower spray arm. Clean the holes in the lower spray arm.
Use a small flat screwdriver to release the tabs holding the upper spray tube from the dishwasher inner wall and ceiling. Rotate the spray tube to the right and remove the tube.
Using a # 20 Torx bit, remove the (about 10) small screws holding in the top of the sump assembly. Remove the top section with the fingers all around it.
Using a # 15 Torx bit, remove the screw holding the round cover over the pump suction. Remove the cover (grab the tab sticking off the corner with a pliers and pull up.)
Anything stuck in the sump will now be visible. If the screen is completely clogged up, then the blade isn't wiping the screen clean. In this case, the screen should be replaced.
The screen is removable, but difficult to re-install. If you need to re-place it, put an open end wrench between the screen and the rotating blade to hold the spring compressed. Also, notice the screen isn't round. The flat edges fit only in the slots they came from.
If it's odor or white powder you want to clean out, use a dishwasher cleaning product such as Dishwasher Magic.
I tell every dishwasher customer: "You do not need to rinse your dishes before washing. But you do need to scrape them off."
Mar 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
No water or rotation to upper rack
if its not letting in enough water then this can happen.check water connections or a motor fault.
Jan 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Whirlpool GU2400XTP Built-in Dishwasher Logo
23 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
