Question about Palm m515 Handheld
Screen won't react to touch
My Palm 515 won't respond to any attempt to use the touch screen. It hasn't been dropped, and why, even when using pressure with the stylus I can get no response. I've tried to reset, and even did a hard reset, but no use. Any ideas?
TIA!
  • 1 more comment
  • Anonymous Jul 18, 2008
    My palm m515 logo keeps blinking and can not reset. When the screen says push up button or down button or any button, it just goes back to the logo blinking. What's the problem?
  • vdak Aug 11, 2008
    My Palm 515 screen touch pad doesn't work properly. When I press abc , 123 , clock or Calculator something else work. This means when I type v in Alphanumeric then i get displayed on screen.
    It seems that Touch Screen ( Touch Pad ) Recalibration required? How to do please advise the proceedure.
    My E-Mail address is : vdak@dohamotors.com.qa
  • paulfcook Aug 24, 2008
    m515 Touch screen will not respond.  Has not been dropped. will not sync.  Fatal error message comes up.  Tried soft reset several times, then several hard resets.  Screen comes up wanting to tap the corners but does not respond to touch.  Touch screen seems completely dead.
SOURCE: Touch screen
You may have dust accumulation around the edges of your touchscreen, between the screen and the case. Try using a can of compressed air. Gently press down on the edges of the touchscreen to expose the gap between the screen and the case, and shoot the air in there. This worked for me when my Treo 600 touchscreen stopped responding.
Posted on Jun 07, 2007
SOURCE: Touch screen doesnt work
try to open the case, clean the screen and the small frame carefully, reinstall and... good luck, mine worked this way.
Posted on Oct 06, 2007
scrodamoon
  • 659 Answers
SOURCE: No response to hard reset
try pulling the battery out and leaving it set for a while. if that dont work are you getting any sound? or just nothing at all? besides the back light working?
Posted on Aug 12, 2008
Just_Bobz
  • 448 Answers
SOURCE: touchscreen doesn't respond
Your digitizer has whacked. Has this been solved
Posted on Jan 06, 2009
ihavsolution
  • 152 Answers
SOURCE: touch screen on Palm Z22 does not respond
http://www.palm.com/us/support/handbooks/z22/en/maintain.pdf
follow this document to do a hard reset...
Posted on May 27, 2009
My ipod screen is cracked and and a couple weeks ago it got dropped while it was raining now the screen won't react to my touch
Your Ipod needs repairing. Take it to an Apple repairer and get a quote. If the repair is too high then put your money towards a new Ipod.
Mar 20, 2013 | Audio Players & Recorders
My phone t23 duo LCD problem. White and black blank screen shows but still respond to touch.
I have the same problem. touch screen still reacts to respond but nothing displays on the screen but all white.
Jul 12, 2011 | Cell Phones
Palm Treo Pro touch screen problem
My phone did the same thing.<br />
Jul 23, 2010 | Palm Treo Pro Smartphone
Touch screen would not respond
HI,
Here is a link to get you to the Palm support page. You can do a phone call to the but it will cost you $25. There is also a chat feature and that looks like it is free so hopefully that will help.
Best wishes.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Aug 16, 2009 | Palm Z22 Handheld
Does not respond to stylus
Try recalibrating the touch screen. Devices with touch screens need to be recalibrated in order to respond properly. The greater the use, the more often recalibration is necessary. I recalibrate my phone once a week. I hope this helps.
May 22, 2009 | Palm Treo 755p Smartphone
Touch screen on lg ku990 seems slow
they reckon if it has a screen protector on it it is "slower" to respond. So if you do have one off... remove it. but yes I do believe my touch screen is abit delayed even without a screen protector :(
Apr 28, 2009 | LG KU990 Viewty
Touchscreen does not respond to touch
This is straight from Palm Support...
1.Press and hold the UP button on the front panel of your device.
2.While holding the UP button, use an unfolded paper clip, or the reset tool at the tip of your stylus, to gently press the RESET button inside the hole on the back of your device
3.The Palm Computing Platform screen will appear. Release the UP button when you see it.
Dec 11, 2007 | Palm Treo 600 Handheld
Screen orientation
PDAs that use touch screens have a very thin membrane over the screen itself that responds to pressure. If this membrane becomes damaged, which it sounds like what has happened, then you're more than likely going to need to have it replaced. You can try doing it yourself, but it's WAY up on the difficulty factor because of the complexity of the connection to the circuit board on the Vx.
To determine if your unit is, in fact, actually damaged, you should first make sure that you've syncronized the unit (which may not be possible if you don't have it set to automatically activate HotSync when the device is attached) then do a "hard reset" to restore it to the factory default. To do this, hold the reset button while simultaneously holding the power button for, at least, three seconds. You will get a message asking you to press up on the control pad to reset to factory defaults. Once the unit is reset, try the screen again... touching even the outer areas to see if there's any response. If it reacts, or beeps at all, then it may be an issue of recalibrating (using the "Digitizer") once it's fully reset. If not, it will need repair/replacement.
Oct 28, 2007 | Palm Vx Handheld
Alm one
PDAs that use touch screens have a very thin membrane over the screen itself that responds to pressure. If this membrane becomes damaged, which it sounds like what has happened, then you're more than likely going to need to have it replaced. You can try doing it yourself, but it's WAY up on the difficulty factor because of the complexity of the connection to the circuit board on the Tungsten E2.
Oct 21, 2007 | Palm Tungsten E2 Handheld
Palm m515 Handheld Logo
50 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
