Question about Toro "Toro" Super Blower/Vac
I need a toro impeller model no 51553 or 51587
  • 183 Answers
The impeller for your Toro blower is part #98-3150 and is available from www.partstree.com for about $20 plus shipping. To avoid shipping charges, find your local Toro dealer. Go to www.toro.com to find your nearest dealer.
An exploded parts view is also provided on partstree.com's website. This should make it easier to see what has to come apart for the impeller to be replaced.
Posted on Nov 12, 2010
Can the plastic impeller on a model 51591 be replaced with a metal #100-9076
Probably but the problem will be when vacuuming
plastic impellers absorb shock from stones and other hard objects, where as metal blades will break off causing an imbalance of the impeller
Apr 13, 2015 | Toro Garden
I'm not asking about a leaf blower It's a toro snowthrower model # 38600. what's the proper way to remove and replace the impeller blades?
You have to disassemble the entire front of the snow blower. This means removing the snow shroud, auger bits and then getting to the impeller blades. I did it once and it took me about 1 1/2 hrs to complete.
Dec 14, 2014 | Toro Garden
Anyone have expierence replacing the impeller on a Toro z master model 74183? This mower vacuums the grass into the rear catcher. The impeller that moves the grass is what I'm referring to.
you have to open bottom to get to impeller once you do that remove the nut and bolt that hold it on you might have use a impeller remover to get off but they hardly ever go bad
Aug 27, 2014 | Garden
My toro model 51599 ultra with metal impeller began to overheat and shut it self off... is there a reset switch...this happened after moderate use tnx
If you take it apart there is a little spring on the bottom of the motor. When overheated it "trips" and looses contact with a wire. Need to reset the spring.
Feb 17, 2011 | Toro Blowers Rake and Vac - Electric...
How do replace the impeller on a toro 51591 super blower vac?
Toro and Sears blowers are pretty much the same. It is not worth the trouble to replace. Good Luck
Jan 06, 2011 | Toro "Toro" Super Blower/Vac
Need impeller # 100-9068
Here you go. $11.99 on EBAY right now:
http://cgi.ebay.com/100-9068-Toro-Impeller-for-51591-51573-51552-Fast-Ship_W0QQitemZ370301014626QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5637a91262
Dec 29, 2009 | Toro "Toro" Super Blower/Vac
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
Nov 13, 2009 | Toro Blowers Rake and Vac - Electric...
Need a replacement impeller for Craftsman blower
toro impellar is the same thing...even same part#(1009068)
May 25, 2009 | Craftsman Garden
Sm.piece broke off spinner wheel; result motor not balanced
yea if you cant fin da company to order the part form which you probably cant youll have to trash it.
Jan 09, 2009 | Toro Super Blower Vac
Toro "Toro" Super Blower/Vac Logo
1,010 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
