Question about Pentax Optio M40 Digital Camera
My camera lens is stuck in the out position and wont retract when i turn camera on makes lots of bleeps and turns off
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 12, 2010
My camera ( finepix jz100) wont open and screen says turn off and on again when camera is turned on
It looks like the lens is stuck or jammed. Is the lens damaged in some way? Make sure the lens retracts fully when the camera is turned off. If not the lens is probably defective.
Oct 19, 2014 | Fujifilm FinePix JZ100 Digital Camera
My samsung pl50 won't turn on it just bleeps at me when i try and the shutter is stuck out. it was working fine when i was taking pics of my sister then it just shut down n won't turn back on
I've sent back 2 phones with this exact problem. Came on here and found the solution on the blog from another camera. It works! Here it is:
Figured it out....the zoom lense, while in the open position, was a little out of line, thus preventing the camera from retracting it. After gently re-aligning the lense, it retracted properly and the camera resumed normal functioning.
So basically, wiggle the lens every so slightly then try the power button again. Hope it works for you!
Jun 05, 2010 | Samsung L200 Digital Camera
The lens gets stuck out and the little green light bleeps but it won't work or turn on -.- what do i do?!??!!?
Put in fresh batteries in your camera and try to power on. If this didn't work, to do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Dec 14, 2009 | Samsung Digimax S500 Digital Camera
KODAK M863 LENS STUCK
Here's what I did...Mine had the lens stuck out and would not power on. Just a green blinking for a second or two. Well, I tried twisting the lens ring closest to the camera while hitting the power button. It's kinda tricky to do...BUT, just keep at it. Mine was a $1 resale shop "find" and now it works. This worked for me. Maybe it will help you!
Apr 18, 2009 | Kodak EasyShare M863 Digital Camera
Zoom wont adjust
Hi there. I can help you with that.
The number one problem with cameras with lenses that won't retract or or move out into position is dirt, grit or sand in the lens mechanism. The best way to fix this is to get an air compressor and put the tip up the lens and blow air into the space around the lens. Run the tip of the compressor nozzle around the lens and turn the camera back on. See if that helps. If it doesn't do it one more time.
If it helps, great. Stop there. If it doesn't help, let me know in a comment and I will tell you a couple more things to do. I want to wait, because they are things that you should only try if you are ready to trash the camera, but they usually work. Hope the air compressor works.
Rob
Feb 21, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
It wont stay on
the same thing happend to me just now... you have to wiggle the lens untill it goes into place then it should retract when you turn it on. :]
May 14, 2008 | Polaroid i531 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Pentax Optio M40 Digital Camera Logo
87 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
