I ordered a cd burner and i dont have the connections to hook it up could you tell me how to correct this problem
  • Dave DeGain
    Dave DeGain May 11, 2010
    What type of DVD burner is it, Brand and model.
    Is it for a computer or your home entertainment center.
    President:
  • 624 Answers
Do you still need help with this problem? If so, please provide the needed information. If not, you can just ignore this post.
Posted on Oct 16, 2008
Which connections do I use to hook it up?
When you break into the computer (disconnected from power, please), the sockets on the back of the burner will only fit a couple of plugs (power and data) - just inspect it closely, don't force the data plug as it goes in only one way. Same for the power plug. Some burners have a little two conductor small plug that hooks up to some sound cards. In most cases you can leave this off if you don't have instructions with your burner. Good luck.
Nov 25, 2009 | LG GCC 4320B CD-RW/DVD-ROM Burner
Hello , I just installed a philips cd burner to my tower machine. I know i installed it correctly I mark all the cables. I have a windows XP operating system . The burner I installed will start up and I...
A few things you can try:
Carefully check that the ribbon cable is firmly seated in the IDE slot on the motherboard.
Perhaps try a new ribbon cable.
Hook up the burner by itself (unplug the power and the ribbon cable from the other CD) Make sure that the burners jumper setting is for cable select or try master and also make sure that the burner is at the end of the ribbon cable not in the center connection
Hope this helps.
Nov 10, 2009 | Computers & Internet
My cd drive is not showing up at all on my computer.when i try to bur a cd it says attach a cd burner...
You must re install the burner and driver!
If it still persists and there is not a loose wire or hook up than call that burner's manufacturer cause there is a defect with it!
Nov 06, 2009 | HP Compaq Presario SR1303WM (PP150AAR) PC...
Samsung cd/dvd combo drive problem
Check you'r jumpers ei master slave. and all cables are hooked up right, power hook up are fully in. you may have to up date win xp. sp 2-3 so on. enter cotroll panel. system. hardware tab. device manager. look under dvd/cd-rom drivers if they are listed there 1st try to update the drivers. if that don't work then uninstall all of the dvd/cd roms listed there. then restart you'r computer. on the re start win xp install wis. shold find the roms and install them and update them. if that don't work you'll have to call the microsoft free help line. this is what they had me do when I had the same problem. you may in the end have to wipe and re install window, sorry to say. hope this helps you
Mar 19, 2009 | Samsung SM 352 CD-RW/DVD-ROM Burner
Lg 20x external super multi dvd rewriter - not working
well, you can try taking the dvd burner out first and exchange places with the other burner. what i mean is may the dvd burner your primary master or slave. try it and post whats happens.
Jun 12, 2008 | Computers & Internet
New powersuply
i dont get what your saying cause if your going to fix it yourself you just need another out of use cd rom but if your looking for the power supply it might be cheaper replacen the burner buy and return this works well
Jun 01, 2008 | Pacific Digital (U-30106) CD-RW Burner
Jumper Setting
* place cd /dvd burners in different channel
* hdd should be set master and ur one cd/dvd burner should be slave
* other cd/dvd burner should be master
May 27, 2008 | Microsoft Troubleshooting Your Web Page...
Compaq presario SR1903WM SERIES
you may need to check to see if you have a CD writeble Rom, open up the computer to see if the cd rom cord is in all the way. I would put a DVD rewriteable in the computer new ones come with the software. you may need a driver. www.download.com
you may only have a CD rom, and you need a CD writer to burn songs. A DVD writer can burn CD's and DVD's
Dec 16, 2007 | Compaq (CDD480172) CD-RW Burner
Check H/W?
sounds like a problem with the internal disk drive, could be damaged and may need replacing... if its still within the warranty return it for repair or replacement.
Nov 29, 2007 | Tascam 2488 Portastudio Multitrack...
Cannot burn CD from Kodak Easyshare Software
If you are using the Pro version of XP, it will burn your photos to the CD itself. As I recall, this didn't work in the Home version of XP, but you could try it. Simply drag and drop the photos onto the burner drive from within Windows Explorer. Once they are all there, I think there's a menu item which tells XP to perform the burn and eject the disk. All that assumes that the burner is working OK on your machine
Aug 30, 2005 | Kodak EasyShare LS443 Digital Camera
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
