I have two Local Area Connections 1 & 2, how can I delete one of them? I don't know why but yesterday I got the window showing me a new Local Area Connection 2. I found it very unusual since I didn't change any settings on the router since I installed it this year and that was the last time windows gave me a window for a new connection (Local Area Connection). While I don't mind having two of them, they seem to be conflicting with each other. My internet connection will suddenly be dropped on both laptops and then I have to click Diagnose and Repair, or disconnect and reconnect again. How can I solve this? I have Linksys WRT120N, Vista 32.
  • hklotus Nov 12, 2010
    Thanks
  • 2,427 Answers
Ok firstly its not the router causing this its the operating system (win vista)
click start control panel
network / internet connection
view / manage network connections
now you will see the two connections there , one will have not connected next to it .. if not simply choose 1, right click and click disable..
thats it your done. ( you might need to r enable that one and disable the other f your internet don't work)
Posted on Nov 12, 2010
Wireless is connected but internet wont detect connection
For wireless connections:
1. Hold the Windows key and press the R key, type services.msc and press Enter or click OK. This should open a new window - services local.
2. Look for Wireless Zero Configuration on the list in the right pane. The list is alphabetical, so you should be able to locate it maybe third from the bottom.
3. Double-click it to open it.
4. Click on the STOP button to stop it (lower left). If it is not highlighted or is grayed out, then the service is stopped. (it should also say that the SERVICE STATUS is stopped).
5. Look for STARTUP TYPE drop-down menu. Change it from AUTOMATIC to DISABLED. then click on APPLY (lower right).
6. Then just change it right back from disabled to automatic and click on apply again.
7. Click on START button (right beside the STOP button) on the same window to start the service.
--- We are essentially restarting the windows wireless service. What we did just turned it off and on again ---
8. Close the services local window.
9. Go to Start and then Control Panel. Network Connections. If you don't see Wireless Network Connections or Local Area Connection after opening Network Connections, kindly look for Network Connections again (it maybe on the lower right).
--- We need to be on the page where you have the wireless network connections icon. ---
11. Right-click on the icon for Wireless Network Connections then left-click on Properties.
12. You should have several tabs. Click on Wireless Network Connections tab (near the top of the window).
13. Make sure you have a checkmark on where it says, "Use windows to configure your wireless connections..." or something like that.
--- Before going into the next step. Kindly make sure first that you have the following CORRECT information: (1) your own SSID; (2) Network key (if you have one) - WEP or WPA or whichever encryption you are using. If you don't know these information, kindly secure these information first or better yet, try calling your router manufacturer to help you out on this ---
14. Then on the list that shows on the same window, remove everything on the list. That list shows all the wireless networks that you have been connected to before.
--- Don't worry about deleting it. The next time that you connect to the wireless network, it will be automatically added back into this list ---
15. Once everything is removed. Kindly close the window.
16. Go back to where you have the Wireless Network Connections icon again.
17. Right-click again the icon and left-click on View Wireless Network Connections.
18. If your wireless router is broadcasting your SSID, then you should be able to see it on the list of wireless network(s) that will appear on the screen.
19. Select your SSID and hit Connect.
20. It should be asking for your network key. Type it in. In might ask you to confirm the network key. Just type it in again.
21. It will attempt to connect it. And you will get a notification that you are connected.
22. Once you are connected, go back to the window where you have the Wireless Network Connections icon we were working on before.
23. That icon should say that it is connected.
24. Double-click it. It should open a new window.
25. You should have a General tab and a Support tab.
26. General tab should say it is connected.
27. Click on the Support tab.
28. Now confirm if your IP Address says 192.168.x.x. where x can represent any number. Example: 192.168.0.100
29. If you have these confirmed. Kindly try to see if you can now get into the internet or into your network.
30. Enjoy!
let me know if this don;t work for you Blankzero
Apr 15, 2012 | Computers & Internet
NOT RESPONDING TO INTERNET
Let's try setting a static DNS server and see if that takes care of it:
1. Click on Start, choose Run, type in ncpa.cpl and press Enter to open Network connections window.
2. In the Network Connections window right click on Local Area Connection and then select properties.
3. Click Internet Protocol (TCP/IP) and then the Properties button in Local Area Connection Properties.
4. Choose Use the following DNS server addresses: and type in 4.2.2.1 for your Primary DNS (you can leave the Alternate DNS blank).
5. Choose OK/Close to the windows and test Internet Explorer
Let me know if that helps
Thanks & Regards
Anas K A
Apr 25, 2011 | Computers & Internet
Error code 8007007e
Unfortunately after reading around, it looks like you have to uninstall Windows Live Messenger then reinstall it.
Feb 15, 2010 | Microsoft Windows Live Messanger
Error 8E5E05F6: You can't sign in to Windows Live Messenger
Hi, If you are receiving Error 8e5e05f6 when you sign into Windows Live Messenger 2009, please try the following:
1. Enable Hidden Files and Folders:
1. A. Windows XP :
1. a.i. Click on “Start”, click “My Computer”
1. a.ii. On the “Tools” menu, click on “folder options”.
1.a.iii. On the “view” tab, locate “Advanced settings” and then follow these steps:
Check the option “Show Hidden files and folders”
Clear the option, “Hide protected operating system files check box”.
Clear the option, “Hide file extensions for know file types check box”.
1. a.iv. Click ok and close the window.
1.B. Windows Vista :
1.b.i. Click on “Start”, click “My Computer”
1.b.ii. In the Explorer window, click “Organize”
1.b.iii. Choose “Folder and Search Options”.
1.b.iv. In the folder options window, click on “View” tab
1.b.v. Select the option “Show hidden files and folders” click “ok”.
2. Delete Windows Live Contacts folder :
2. a. Click on “Start”; double click on “My computer”
2. b. Browse to the location
Windows XP:
C:\Documents and Settings\<Your Windows logon name>\Local settings\Application Data\Microsoft
Windows Vista:
C:\Users\<Your Windows logon name>\App Data\Local\Microsoft
2. c. Delete “Windows live contacts folder” completely.
Note: Ensure to exit Windows live Messenger from the task manager before deleting Windows live contacts cache folder, otherwise you will get an error prompting that you can’t delete the folder .
2. d. Try signing into Windows Live Messenger.
Sep 19, 2009 | Microsoft Windows Live Messanger
How do I fix Error 8E5E05F6
Try the following:
1. A. Windows XP :
Windows XP:
Windows Vista:
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
Internet Won't Connect
Press Start->Connect To -->Show all connections.
If the Local Area Connection icon is crossed with a red X, right click it and choose (Enable, or Repair).
If there is no Local Area Connection icon, you must create a connection.
In the left panel in Network Connection window click create new connection.
1.The wizard pops up
2.Click Next.
3.Put a (dot)mark in Connect to the Internet .
4.Click Next
5.Choose Set up my connection manually
6.Click Next Choose the type of connection you have with you ISPN (dial up, etc.)
7. Click Next , and follow the instruction from here.
Hope it helps you find your way to a solution
Aug 30, 2009 | E-Machines Computers & Internet
Network Connections missing icon. Plus others problems.
XP tags "Local Area Connection #" with your Network Adapter. If you have a built-in LAN, it will take Local Area Conn 1" and when you disabled it and plugged in a new network adapter, it will be named Local Area Conn 2 and so on in that pattern. Your Local Area Connection will only be back when you plug the original Network adapter that XP tagged as Local Area Connection. It is not "variable" where you can choose how to name it.
Jul 31, 2009 | Computers & Internet
Need to find network driver
Solution:
i) Click on  Start button ---->Select option Control Panel------>Select Network Connections----->
   a new window appears showing the "internet connections icon " Such as:
   Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:   Local Area Connection 1 or 2 or 3
       Network Cable Unplugged, Firewalled
       VIA compatible Fast Ethernet
   in this case u can download VIA network drivers....from internet..
       or
  eg2:  Local Area Connection 1 or 2 or 3
          Realtek RTL8139 Family Fast Ethernet NIC
   in this u can download "Realtek RTL8139" network  drivers.... from internet(which is showing model    no: RTL8139 through google search engine )
                                                          (OR)
ii) Click Start button ---->Select RUN option ----> type in the text box    devmgmt.msc  --->Select Network Adapters....
but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the correct Model NO: of VIA or Realtek....
so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Dec 27, 2008 | E-Machines eMachines Refurbished EMA...
My computer (Dell) unknow Network Card
  or
        (OR)
    but this will show wheter ur network adapter or NIC is VIA or Realtek or......but doesnt show the           correct Model NO: of VIA or Realtek....
Thanking you
M.Sridhar
Dec 25, 2008 | Dell Ethernet Card Network Adapter
Dell Ethernet Network Adapter not being recognised
                      or
                                         (OR)
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
