Question about Dell Dimension 2400 PC Desktop
I have dell dimension 2400 desktop machine.. the dvr drive/cd rom icons are not showing in my computer window. not showing in bios even?? pls kindly give a solution for this..
  • 358 Answers
Try this quick fix :
Get a screw driver, unscrew your machine and remove your drive. If you cant do this by yourself,
just try and get a good technician to do it for you.
After this, power up your system normally without the drive connected.
Then shut down properly, and reconnect the drive, making sure that its firmly connected.
Then power on again and check it in the system BIOS if its now detected, then save and exit,
then boot your system properly again.Then when the system boots, just right click on my
computer, then properties, then select the hardwares tab, then click on device manager.
When you get to device manager page, try and locate DVD/CDrom Drives, then click on it, if your
drive is there, then just right-click on it, and select uninstall, and after this, on that same page,
click on 'Actions', and select "Scan for hardware changes". But if its not there. Just click on the
"Actions, and Then select "Scan for hardware changes".
This should automatically out it back inside your My Computer page.
Hope this helps you out.
Posted on Nov 12, 2010
Have a used dell dimension 2400, hard drive died i replaced it, but i dont have the original os disc that came with the system, can i use my copy of vista, or find another copy
If your Dell computer had Vista installed then you can use your copy of Vista CD and you can use the product installation code that is printed on the Windows label that is attached to your Dell.
When you insert the Windows CD into your Dell and boot up your computer then select the CD as the boot device (ie 4=IDE CD).
After Windows is installed and activated then you need to install the Dell computer's device drivers.
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
Hi, I have a Dell dimension 2400 desktop. I plugged in a (wiped securely) hard drive. After it loaded the DELL LOGO BIOS, it shows a blank screen with a " dash -" on the top right corner. I...
try tapping the F12 key over and over when you see the DELL Screen to bring you to the boot menu....with your CD in choose to boot from the CD and it should allow you to run the OS installation from there.....your machine is trying to boot from the hard drive that has no OS on it.
Mar 29, 2011 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 won't recognize DVD-ROM drive as Boot Device.
Enter the Bios and under System Components find the Boot priority in the Bios and move the drive to the top of the list, also you can press F12 at Start up to select it as well. :)
Apr 14, 2010 | Dell Dimension 2400 PC Desktop
Can i burn dvd-r with my dell dimension 2400 windows xp
Hello, if you havent bought a DVD writer for your computer no because your computer comes with a CD-ROM only
Feb 04, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Will not recognize dvd rom
Try going to add hardware in your control panel and have the dvd-drives' driver disk on hand.
What are your computers specs?
Jan 02, 2009 | Dell Dimension 2400 PC Desktop
Not show
First check your BIOS setting...Be sure that your DVD drive is enabled...You can also see wether your DVD Drive is enabled in Device Manager.(Rigt click on MYCOMPUTER Icon, goto properties and goto Hardware Tab)
Check the cables (power & Data) connected properly to your DVD drive.
if problem arise again there would be aproblem with the data cable. So replace it with another one
Sep 27, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
