Question about HP LP2065 Monitor
I have a HP LP2065 monitor, and it is currently displaying lines (red, blue and green) vertically on the screen, how do I resolve this problem?
  • 6,831 Answers
Hello
OK, firstly, this problem can be due to a couple of factors. I will explain it in as much detail as possible.
Internal cracked LCD:
This is the most probable cause for these lines on the screen. Unfortunately this is not something which can be fixed without replacing the whole screen.
Damaged DVI cable:
A faulty DVI connection between the computer and the LCD screen will also cause this symptoms.
Faulty Graphics Adapter:
Lastly, this can be due to a faulty graphics adapter. If you use the on-board adapter, i would suggest that you first test the graphics adapter with another screen. Also, take out the graphics adapter and place it back in, just to make sure that there is not bad connection.
With all of the above explained, i will suggest that you start by testing the system with another screen. If the problem persists, check the connection with another cable.
If all else fails, have a look at the graphics adapter you are using.
Feel free to let me know if you need any further assistance.
Kind regards
Andrea
Posted on Nov 12, 2010
Lp2065
if screen black but green light on then is inverter was bad.
if screen black n green light off or amber then check then monitor defective.
Try with different monitor and result the same problem, either the monitor or the video connection.
Apr 01, 2014 | HP LP2065 Monitor
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
Lcd vertical lines
Hook a spare monitor to the computer, if okay! the problem is with the HP monitor "LCD panel defective" not cost effective to repair. But if symptoms are the same for both, the video graphics card on the computer is defective, sub a video cord from the computer to the monitor if possible to cover all angles.
Mar 13, 2012 | HP LP2065 Monitor
I have vertical lines on screen I have changed the whole screen assembley but lines are still thers , exactly in same place
Hey There,
The reason this happens is because the graphics card is either loose burned out or jsut needs to be cleaned... to clean it use a pencil rubber in the gold tips that connect it, blow on the card to remove any dust build ups and reconnect the graphics card when done (make sure its clipped in properly).... different brands of computers will do different things such as the different coloured lines and screens flashing red. My dell latitude 630 had green and blue verticle lines. Just follow what i said and it should be fine
Hope this will help you in Resolving the issue with the vertical Lines on the screen.
Cheers!!!!!
Vivek
Feb 14, 2010 | HP Compaq nx6325 Notebook
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
No Display on IBM G42 CRT Monitor's screen
if u change monitor . you came to know fault of monitor or cpu., if monitor works cpu is not woking properly..some itime we face same problem to creat by changining highgraphic. we can reduce graohic by using f8. re instiling xp we can solve that type of some problem.
Jun 15, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
HP LP2065 AS 2ND MONITOR
Make sure in the control panel under power options you change the settings so the screen doesn't go into sleep mode and make sure the display doesn't turn of. Do this by changing the times to never.
Feb 08, 2009 | HP Computers & Internet
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Jan 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
HP LP2065 Monitor Logo
234 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
