Question about HP Computers & Internet
When i turned on my hard drive it started to boot up then all of a sudden this alarm (sounds like a car alarm) went off and it shut back down.
    Problem Solver:
  • 9 Answers
These beeps you are hearing are warning beeps. The first thing i would try is if you have 2 ram sticks in take the one out and boot up if it still beeps put the ram back in and remove the other one. Or it could be dust on your ram or in the slot so take a paint brush and lightly dust the ram and the slot.
The other possibility is your cpu over heating the you will need to take the heatsink and fan off and dust it out as the dust could be blocking the air flow thus over heating your cpu.
Posted on Nov 12, 2010
Asus repair
Take the hard disk out of it or set it to boot the CD drive first and see if gets any farther. Most likley the hard drive is bad.
Oct 28, 2013 | ASUS Computers & Internet
My laptop won't start... please
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
Jun 16, 2010 | Toshiba Satellite L25-S119 Notebook
1996 Dodge Avenger Security System went crazy now car won't start
try to put the key in the ingnition and turn it to the on possition and walk away for about 15 min come back turn it to off and see iff it starts
Dec 30, 2009 | 1996 Dodge Avenger
I was driving my car the other day and it turned off completely.
The most likely cause is a broken earth wire and or bad connection
Jul 10, 2009 | Chevrolet Lumina Cars & Trucks
The alarm on my 97 Acura cl went off, how do i shut it off.
if the alarm is a factory alarm, sitch the key in the drivers side door and turn it both ways.
Apr 08, 2009 | 1997 Acura CL
Alarm wont shut off and lights keep flashing
This can be very simple look for alarm brain and unplug the brain, this vehicle should start. if it doesn't the look for valet switch it usually mounted under dash or on kick panel next to hood lever or close to where clutch pedal will be, Turn Ignition ON and in ON position flip switch the led light should stay on steady then the vehicle will start. If None of this works then you will have to take panel under steering column down and disconnect complete alarm system. Disconnect wires one ar a time and re-join them with the correct ones. It's NOT hard to do, there will be spliced into ignition wires.To do this you should disconnect positive lead on battery pole to stop the annoying noise until you are done. Good luck and contact if you need more help. Thanks for using FIX YA
Mar 24, 2009 | Vehicle Parts & Accessories
SimpleTech 320GB Hard Drive- unable to detect the device
I had a similar problem with a SimpleTech 250g Pininfarina USB drive.
I went through the drivers, the power supply, the USB cables, and the various
computers, USB cards and Operating systems.
Finally I opened the case and found the disk drive was mounted too far
forward, causing the IDE connector to barely touch. I loosened the mount screws,
slid the drive back towards the connector, tightened everything down and it works.
Mar 15, 2008 | SimpleTech Pininfarina 80GB External USB...
M35X Screen went black and will not come back on after shut down, reset and power up
Try to connect to external monitor and see if you see anything. Of course when you do that you have to hold at the same time fn key and the key that has a blue picture of computer screen.
Jan 17, 2008 | Toshiba Satellite M35X-S149 Notebook
Computers & Internet Logo
182 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
