Question about Refrigerators
Whirlpool refrigerator leaks water inside the frig. It gathers in the pan under the lowest sliding drawer. Possibly something to do with the icemaker? I don't use the icemaker -- I flipped up the bar inside the ice collection bin so it wouldn't make ice. However, I think the frig. tries to fill it anyway.
  • 3 more comments
  • furryhermit Jul 14, 2008
    I'm having a similar problem with our Whirlpool. I've just noticed this problem this summer, however I just recently got
    married and there is more frequent activity going into the frig and
    more food stocked in there as well. In the past, this usually meant that the door was left ajar and that moist air was getting inside and condensing. I adjusted the door and tipped the frig back a bit to help the door "auto close" better, and this seemed to help for a while, however we just had another wet episode this weekend, so I'm not sure that was the problem. I'm open to other suggestions.
  • clayimage Sep 11, 2008
    My Whirlpool fridge leaks on the inside.  What can I do to stop the leaking..It is coming from the middle back top of the fresh food compartment.  What do I do?
  • Anonymous Sep 29, 2008
    water leaks inside my whirlpool refrigerator also. any solutions??
  • Anonymous Oct 12, 2008
    I too have the same problem. It appears that the leak is coming from the water maker. It is damaging my floor as well.
  • Mantas4 Jan 05, 2009
    Water leaking inside of whirlpool refrigerator
Its a done deal...:) On MY whirlpool MODEL # ETICHMXKBO3 I found the drain hole frozen.. There was some debris and clogged it up and water froze up behind it causing the deck of my freezer to fill and freeze up and cause the water to drain into the fridge. Solution: remove the ice maker(if equipped) remove the rear aluminum cover. I used a heat gun and melted the 1 1/2 of ice build up and softly with a screw driver clean the drain. When drain is visible use scolding hot water until it starts flowing to the bottom tray. I used my air compressor to finish it off....
Posted on Dec 13, 2009
We have had a Whirlpool for about two years and the water leaking problem has happened about three times. We fixed it ourselves using lots of towels, hot water, and time. See this website which describes the problem and how to fix it: http://www.applianceaid.com/frig_leaking.html#inside
Good Luck.
Posted on Feb 19, 2009
    Problem Solver:
  • 12 Answers
We own a Whirlpool fridge and after several years it began leaking water into the fresh food section.
Posted on May 25, 2010
  • bassplayer70 May 25, 2010
    Unplug fridge, remove the ice maker, remove the back panel that covers the evaporator coil use hot water to melt the ice that is covering the drain hole and then use a turkey baster to shoot hot water down into the drain hole. Check the water tray at the bottom back of the fridge to see if the water is coming out when you shoot it down the drain hole.
I am no appliance repairman, but have had this problem on a fridge in one of my rental houses. I tore the machine apart and realized that the defrost heater did not have continuity. I am going to replace which should solve problem. If you just get drain line cleared without solving problem you will be redoing before long.
Posted on Jul 10, 2012
  • Brandon
    Brandon Mar 01, 2014
    Hey Don, you are exactly right i unclogg mine and about a month later it does it again...how do i know if the defrost heater needs replaced and where its located at? thanks
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire Gallery, model GLRT183TDW0 Water is leaking underneath, and water is collecting in the bottom under the crisper drawers
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Oct 27, 2010 | Frigidaire Refrigerators
Water at bottome of refrigerator
Under the draws in the back, there should be a drain hole that drains water down to the drain pan under the unit. Check to make sure it's not blocked with food or frozen water.
Jul 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
Water collects inside the frig
usually an indication that the drain tube is clogged with frozen water or blocked woth something clean the drain tube.
Mar 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Jan 21, 2010 | Frigidaire Refrigerators
My refrigerator is leaking water , i don't have an Ice maker, it appears to be condensation and gathering at the bottom and leaking out
take all the stuff out of your freezer compartment. take out all the screws that hold the panel on in the back of the freezer compartment. under the evaporator coil there is a metal drain pan with a drain at the lowest point. this is most likely plugged with an ice chunk or some kind of food gunk. a turkey baster with hot water in it will most likely clean it out. if you see the evaporator all iced up then you have bigger problems. a secondary problem is that where the condensate drain runs to, the pan could be cracked or there could be something causing the water to wick out of the pan and onto the floor. this pan is in the back of the fridge behind the access panel or some can be reached from the front behind the grill.
Oct 10, 2009 | Whirlpool Refrigerators
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Whirlpool frig model -et9fttxlq11 serial-9m5110756 inside at very back water comes out of this opening
Your issue is;
"whirlpool frig. model -et9fttxlq11,serial-9m5110756
inside at very back water comes out of this opening"
Thank you for providing a valid model number!
This link shows exploded view of your model.
http://www.repairclinic.com/0100_2.asp
Water can leak from these areas:
The inside ceiling of the refrigerator
The inside back wall of the refrigerator
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
    The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
    The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
    Please show your appreciation by rating my solution.
    Thank you,
    Dave E. (Illeagle)
    "Your satisfaction is my personal reward"
    Jul 24, 2008 | Refrigerators
    Kenmore side-by-side 106.52764100 Frig leaking water
    Do you have a Dog ??? I had a customer who had a problem like this once.................Only to find out in the middle of the night the dog jumped up and with his nose pressed the water dispenser..If not plz check inside the freezer and see if your drain is clogged pull the bottom drawer out and look on the back wall..
    PS: the pan even with a clear drain will not fill up the condenser fan with the heat from the condenser will evaparate the water after a defrost cycle
    Feb 23, 2008 | Refrigerators
    Refrigerators Logo
    13,044 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
