Question about Canon ZR20 Mini DV Digital Camcorder
Have a canon zr20. everytime I place a tape in it it tells me to eject the tape and when I do the tape is pulled from the cassette like the camcorder is eating it.
    Genius:
  • 1,812 Answers
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on Nov 15, 2010
Everytime I put a cassette into it, it always says to eject or remove cassette, why is this?
Most of the time this happens is when the tape in in the save mode. check to see if this is the case before inserting.
Feb 07, 2011 | Canon ZR100 Mini DV Digital Camcorder
Everytime a place a cassette in the recorder...it makes a high pitched wine sound and ejects the tape...and says "remove the cassette" with 5 "beeps" following. I've read these complaints on other...
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Oct 18, 2010 | Canon ZR200 Mini DV Digital Camcorder
Canon zr20 wont eject tape
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 06, 2010 | Canon ZR20 Mini DV Digital Camcorder
I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
Jun 16, 2009 | Canon MV800i Mini DV Digital Camcorder
How to convert dv tape from Canon ZR20 to MY COMPUTER hard drive?
To transfer video off your minidv cassettes from your camcorder you would need to have a firewire connection to your PC. Either a 4 to 4 pin connection (laptop) or a 4 to 6 pin (desk top computer). USB is used only for picture still transfer. Here are the steps;
1. Plug your mini Dv camcorder into an outlet
2. Plug in you firewire connection into your computer, then plug the other end into your camcorder.
3. Turn on your camcorder and switch your camcorder to Play/VCR
4. Select the software that you want use to do the transfer. Windows Movie Maker is the most assessable software since you have XP on your computer
5. Name your file
6. Select capture from video device (automatically will allow you to save the entire tape and manually would allow you to capture parts of the tape).
Those are the basic steps in some detail. You can save your file from there or you can go on to edit.
Jan 02, 2009 | Canon ZR20 Mini DV Digital Camcorder
Cassette removal from dead Canon MV650 Camcorder
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
Nov 13, 2008 | Canon MV650i Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Canon zr20
Try toggling the opening hatch, tricking the machine into thinking it's being opened and closed...
May 24, 2008 | Canon ZR20 Mini DV Digital Camcorder
Condensation found
inspect the flex around the chassis when it comes out it is brown sometimes it comes loose or breaks and you will get that message. you could take the cassette cover off and get a better look just follow every flex to were they go and look closely for cracks.
Dec 24, 2007 | Canon ZR20 Mini DV Digital Camcorder
Canon ZR20 Mini DV Digital Camcorder Logo
153 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
