Question about Zebra 110Xi III Plus Thermal Printer
Z110xilll after 3or4 labels paper out error - Zebra 110Xi III Plus Thermal Printer
    Champion:
  • Zebra Expert
  • 285 Answers
Please run manual calibration
(take 2 or 3 labels and load the labels under the printhead and sensors, close printhead, press enter,
if ask for "take the ribbon," just open the print head, take the ribbon out from the sensors, close printhead, enter.
then if ask for load media, just put everything like you normaly setup the printer and press enter. The printer gona run the calibratio, Please close the door case, this can afect the sensors data.
save
tur off the printer and back on again.
run sensor profine. check if sensor check the gap (smal mountan )
Posted on Nov 12, 2010
Continually getting a "Paper Jam" error. Paper
we had this issue
Clean the pathway/rollers/sensors included with IPA..should solve it..try changing the ribbon too.
There must be some paper piece or oozing of adhesive...or the paper width might be holding the unwinding.
ASHOK
Jan 28, 2011 | Citizen CL-S700 Thermal Label Printer
I am trying to print a label through the document feeder and keep receiving error messages on my Brother MFC9320CW AllInOne Printer .."Open the Top cover and pull out all 4 drum units completely and...
Try putting more than one sheet of labels in the paper tray. Even if you're printing one label, it helps the printer grab the paper without that error somehow. If you're already using more than one sheet, I don't know. Good luck either way!!! :)
Jan 18, 2011 | Office Equipment & Supplies
LP2844 printer stops after one page with out of paper error
Did you try to reload the labels. Pull the labels out and clean the paper path
May 07, 2010 | Zebra LP 2844 Thermal Printer
Paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
Out of Paper Error
You get the error because the printer doesn't see any paper.
There are paper guides that need to be set for the size of the labels being printed. If you are switching from a 4" wide roll or sheet to a 3 1/2" label, you will have to move the slider in about 1/2". You will also have to calibrate the printer when you change label stock. If it won't calibrate, make sure the photoeye is hittint the break between labels. The photoeye is located where you insert the labels into the printhead path.
Feb 05, 2009 | Zebra Z4M Printer
Zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
Jan 16, 2009 | Zebra 105SL Thermal Label Printer
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Zebra 110Xi III Plus Thermal Printer Logo
128 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
