Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
I could not able to connect my harddisk with my pc but it get connected in my laptop
    Problem Solver:
  • 9 Answers
It could not be getting enough power, if you are using the front USB ports try the back ones. Or if your external hard drive has two USB's on the cable you plug it into the PC then plug both in for extra power.
Posted on Nov 12, 2010
How can i boot my acer 1640 laptop from usb drive (external dvd), the bios have no option. Thanks
Do you still have the problem?
In BIOS setup go to the Boot section and move the cursor down to the harddisk line.
If you started your PC with the USB device connected, the Harddisk line should have a "+" to the left.
Press enter on the Harddisk line and move to the USB.. line.
Press F6 to move it upward.
Do the same to move the Harddisk line to the top before the CD/DVD line.
Save the settings and rebootReboot, and it should boot on the USB device.
I have an Acer Aspire 1640Z, and I use a USB key to install UBUNTU Linux
Sep 19, 2010 | Acer Aspire 1640Z Notebook
Can't turn on just hang
if u changed the BIOS battery on the motherboard and havnt re installed the BIOS it Wont Work.....
Mar 24, 2010 | Acer Aspire T310 PC Desktop
Hye..my acer aspire laptop very bad causes of virus infection and mess with all my files and folders. so, it think reformat is the best solution for me. But unlucky, when i restarted my Laptop and install...
Hello !
You have said that you have done installation and Harddisk are not recognised this is a indication of damaged Harddisk ie its registry is bad or its not working .
I recomend a new Harddisk then you will able to use your laptop
Before you change the harddisk you should check the IDE cables by swapping them coz sometimes they could be faulty, connect new cable to the harddisk then on it try installation again .
Good luck
Nov 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Is it possible to get the data of a hard drive that pc & laptop cannot detect
its possible to get data from harddisk of the pc, make sure you have connected power to harddisk and its data cable to your laptop so that it will be detected
Oct 19, 2009 | Dell Inspiron 1525 Notebook
Four months i bought a 320 gb harddisk for my laptop. later now the laptop didnt start. i removed the harddisk and replaced with other harddisk. its working.i have lot of data on that harddisk. when i...
For getting data off of old hard drives, a USB to IDE/PATA connector is a wonderful tool. My favorite is like this one, with a dual head - one side for 3.5" & 5.25" IDE drives and the other for 2.5" IDE drives. That covers the vast majority of older consumer-level equipment.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1871517&CatId=3770
Just hook your old drive to a device like this, then plug it into your USB port. It will automatically show up as an extra drive so you can copy the data off.
Jun 03, 2009 | IBM ThinkPad T30 2366 Notebook
DELL DESKTOP PC
check in bios your harddisk is detected or not.
if your harddisk is not detected then u have open cpu then replug power and data cvable connection to your harddik and mother bord again.
then u can detect harddisk.
it is issue of loos connection betweeen harddisk and motherbord.
check it .
Apr 06, 2009 | Dell UltraSharp 1905FP LCD Monitor
250gb Maxtor External HardDisk not responding
How are you connecting it to your pc?  are you supplying external power?
Jan 01, 2009 | Maxtor Hard Drive
Installing extra hard drive
before opening cpu just confirm that the another harddisk is master or slave by going to BIOS set up or CMOS setup....
then open you cpu
see near the harddisk which is already connected ...
then do the following:
first you have to make jumper settings .. if the harddisk which is already connected is master then you must make the extra harddisk slave by shifting the jumper to next two pins .... about jumpers it will be defined on the harddisk label refer it....
just refer this simple dots as pins which is parallel.. ... if you want to make master then you put the jumper to this first pins parallelly if you want to make slave then put in to second pins parallely...
then
1. there will be one bus which is left empty parallel to the harddisk which is already connected... the bus will broad and it will be in white colour ... connect it to extra harddisk correctly...
2.there will one more parallel power supply which will be have 4 pins small one ... connect it to extra harddisk the yellow wire must be facing you....
then just switch on the pc and check in bios settings the extra harddisk is detected or not... if not you have not connected properly connect it properly...
Feb 18, 2008 | Computers & Internet
Seriel port problem? or Harddisk Problem?
If thats the case try to reinstall again the driver and software of your TATA Indicom FWP phone and then if it wont work try to reformat it. If not work again check your phone. Hope it help
^_^
Dec 04, 2007 | Computers & Internet
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
