Ignition switch how to install a ignition switch in my 2004 buick century
  • 74 Answers
This is a KVM switch as in COMPUTERS not Cars, i do believe their is a section for this though
Posted on Jun 18, 2008
Where is location of netueal safety switch on 04 century
Here's a link showing where the switch is. Questions Answers for Buick Century neutral safety switch bypass
Mar 14, 2017 | 2004 Buick Century
My main speakers are not working in the back of car
Buick Century Audio - Radio, Speaker, Subwoofer, Stereo
www.crutchfield.com/.../Buick-Century-Stereos-...
Crutchfield CorporationFind car audio products that work with your Buick Century ... your Century, 2005 Buick Century Sedan, 2004 Buick Century Sedan, 2003 Buick ... Here are stereos, speakers, and subwoofers that work with the Buick Century ... Rear Speakers .... time to talk to you through installation snags, troubleshooting, or everyday use.
Aug 30, 2015 | 2003 Buick Century
How to replace ignition switch 1983 buick century?
Shop manual shows procedure. If regular parts store can't supply switch check ads in Hemmings Motor News.
Feb 26, 2015 | 1983 Buick Century
2004 buick century,security light stays on, no problems with starting/driving, how can I reset turn off? tried the 10 min/turn key to on poss,didnt work
The security light is probably on because of the key tumbler sensor where the ignition switch is at is bad or corroded. The security light on while your able to start it means the anti theft system is disabled and it will start every time. If you want you can replace the sensor on the tumbler for under $100 on your own or run to a junk yard to grab a replacement sensor.
Jan 26, 2015 | 2004 Buick Century
How do i get into a 2004 buick century without the key remote
does it not have normal key hole in the door to manually unlock.
Jan 10, 2015 | 2004 Buick Century
2004 buick century Ihave no power in the white wire going into the brake switch, but I have power in the orange wire going into the brake switch.
Unless the brake switch is defective, you'll have 12 volts on the white wire when you step on the brakes. You can verify this by noting that the high level stop lamps work
Oct 10, 2012 | 2004 Buick Century
How to remove 89 buick century ignition switch
Hi iribosa. Here is the step-by-step instructions:
1. disconnect neg- battery cable,
2. then remove lower interior covers 7mm screws or 9/32.
3. locate cable for shift indictor remove with small pick.
4. locate two 15mm bolts faces upward remove them .steering column will lower.
5. next you will remove dimmer switch. apply small piece of tape to actuator rod then remove 1 mount 5/16 bolt 13/8 nut set aside or leave hang by the wires.
6. disconnect wiring to ignition switch, then remove remaining bolts.with key in lock position remove switch from rod this actuator rod is for ignition switch.
to install the new ignition switch work from 6 back to 1. Joe
Thanks for choosing Fixya!
Dec 09, 2010 | 1989 Buick Century
The Ignition switch is stuck in the on position and I can't shut off my 1994 buick century. How do I change out the ignition switch
Does your Buick have an airbag in it on the drivers side? If not i can walk you through step by step. If it does i would not recommend doing it your self.
Nov 11, 2010 | 1994 Buick Century
I cant unlock my car with the remote or the key
The ignition key does NOT open the door lock on my 2004 Buick Century, but the Valet key does. I just thought that was how it was supposed to work.
Jul 20, 2009 | 2004 Buick Century
Computers & Internet Logo
David Payne
David Payne
