Question about Philips 37MF231D 37 in. LCD Television
Where can i buy the capacitors ,radio shack does not have them
    Problem Solver:
Mouser electronics, just give them the spec and dimensions
http://www.mouser.com/
Posted on Nov 12, 2010
Tip
Building Power Supplies
Get you a 12 to 15 volt Transformer. Buy two big power diodes from Radio Shack. A capacitor 100uf to 470uf that handles 16 volt or 20 v. Buy two 0.01uf Disc capacitors. Get you a board 6x6 inches. Bolt down transformer to board. Hook leads to Diode like this: One lead to Striped side of Diode(1). the other lead to Diode(2) opposite side. Use capacitor 470uf (+) to striped side of Diode(2). Use capacitor(-) to Black side of Diode(1). Make sure polarity is right + - etc..Solder 0.01uf capacitor across Diode(1) and Solder other 0.01 uf Capacitor across Diode(2). Parallel wise. This Bypasses Rf so you get no Hum. There you go simple 12 Volt DC current to run mobile radios indoors.
on Apr 01, 2011 | Radio Communications
Where can you buy capacitors? I have a Polaroid DRA-01601A and at least one of the capacitors is blown. Specifically CE10 from what I see on the mother board.
You can buy capacitors from many places. Radio Shack as a local store. Digi-key as an example.
Jim
Preston Computer Service
www.prestoncomputerservice.com
May 21, 2011 | Computers & Internet
How do you replace capacitors
First you have to find replcament capacitors from the TV manufacturer on the internet. then you learn how to disassemble your TV and power supply, to use screw drivers and soldering iron. Then you can replace any capacitors. Radio Shack salesmen can help technically.
Aug 16, 2010 | Philips 42PF9631D 42 in. Plasma Television
Whear i can by a capacitor 35v 680uf for model is-lcdtv32
U try Radio Shack yet?Go to websites like Aamazon.com,Ebay.com have many capacitors to chose from.
Jun 18, 2010 | Insignia IS-LCDTV32 32 in. Television
Blinking standby light need new capacitors? philips 50pf5532d, where do we buy capacitors? is this an expensive job?
No,around $50-75 by buy a soldering iron,solders and all those new capacitors replacement.U must know basic electronic,and soldering to do the capacitors replacement.You could buy capacitors many plaaces like ur local Radio Shack,Amazon.com or Ebay.com.
May 21, 2010 | Televison & Video
Mitsubishi WS-65513 flashing green light
I would not recommend buying the replacement caps from Radio Shack. Buy online from Mouser or Digi-Key. You'll get quality stuff.
Order 8 1000uF 16VDC 105C rated can capacitors with leads that come out the bottom, not each end.
You can find instructions on how to make this repair by doing a search for Mitsubishi capacitor replacement. You'll find a number of instructions for disassembly and reassembly.
Let me know if you need additional help.
Dec 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
My Acer AL2017 "flashes" on then off when I hit the power on button. It does it repeatedly. If I cycle power enough times it will eventually remain on.
This is the same issue I had AND....you can fix this by replacing 5 capacitors in the screen Power Board, So here we go: go to Radio Shack or similar store that sells capacitors and buy (3) 220 Microfarad capacitors Radio Shack Part Number 272-1029 and (2) 1000 Microfarad capacitors PN 272-1032. Now on your board you will see the bulging capacitors just remove them and replace them with the new ones. PAY CLOSE ATTENTION to the polarity, there is a negative stripe on the side of the capacitor. Make sure it goes back in the way the old one came out. Now the radio shack capacitors are 35vdc and the stock capacitors are 25vdc and the new capacitors are bigger in diameter but the difference is ok as long as the Microfarads are the same. Mine were replaced and all is well now
Sep 18, 2009 | Acer AL2017 20" LCD Monitor
Acer AL2017 has trouble starting up.
I CAN FIX THIS or rather you can there are a total of 5 capacitors in the screen Power Board, that upon inspection the ends are bulging therefore they are bad. So do this: go to Radio Shack or similar store that sells capacitors and buy (3) 220 Microfarad capacitors Radio Shack Part Number 272-1029 and (2) 1000 Microfarad capacitors PN 272-1032. now on your board you will see the bulging capacitors just remove them and replace them with the new ones. PAY CLOSE ATTENTION to the polarity, there is a negative stripe on the side of the capacitor. Make sure it goes back in the way the old one came out. Now the radio shack capacitors are 35vdc and the stock capacitors are 25vdc and the new capacitors are bigger in diameter but the difference is ok as long as the Microfarads are the same. I preformed this and my monitor works Outstandingly well with NO problems yea I’m a happy camper.
Jun 07, 2009 | Acer AL2017 20" LCD Monitor
Where I can capacitors of circuit board, please help
The more important are the microfarads on the capacitor it can be 1000 mf,470mf you check the number in the body of the capacitor you can buy it in any radio shack.
Jun 09, 2008 | Cyberhome CH-DVD 300 DVD Player
Philips 37MF231D 37 in. LCD Television Logo
180 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
