Question about Motorola Mobility MOTOROKR EM330 Cell Phone
I CAN'T GET MY PHONE TO CONNECT FOR BLUETOOTH IN MY NEW KIA SOUL.IT SAYS IT IS PAIRED, BUT WHEN I GO TO USE IT, IT WON'T CONNECT.
How do i link my phone bluetooth to a 2013 kia soul
Hi Daniel,
To pair your bluetooth-compatible phone, follow this step-by-step list:
(Make sure bluetooth is turned on on your phone)
1 Press the "Talk" button in your car while the engine is running
2 Say "Setup"
3 At the setup menu, say "pair phone"
4 After being asked to say yes, say yes
5 Say a chosen name for the phone
6 Say yes
7 On your phone, search for bluetooth devices
Your phone will display the car name (Soul)
8 Connect with "Soul"
9Enter the 4 digit pairing key in your phone
Kind regards,
Elias
Jan 23, 2014 | Radio Communications
2010 Kia soul car alarm won't stop blinking.
I think one of your door latches was not closed all the way. Check that first.
Aug 03, 2011 | 2010 Kia Soul
Bluetooth quit working on my LG Dare. It was connecting to my car and my laptop but now it won't connect to anything.
my lg incite cell phone was working whit the bluetooth conection in my kia soul car but now my cell is frozen and reset and still same
Feb 23, 2010 | LG Dare VX9700 Cell Phone
Pairing the Samsung WEP 210 headset to my Samsung Soul phone
Pairing Instructions
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
Ensure that the headset is off (see Turning the headset on/off).
Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a Setup, Connect, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices.
Your phone will find the Samsung WEP210 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
Aug 21, 2017 | Samsung Bluetooth Headset WEP-210 B2700...
How do I add a 2nd phone to motorola bluetooth headset h710?
after you connect one phone. go into phone settings and turn off bluetooth. go to second phone open bluetooth options. not put your h710 into pairing mode. once paired, go back to original phone, turn bluetooth setting back on, and both devices are now paired.
Jul 03, 2009 | Motorola Mobility H710 Bluetooth Headset
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
Jun 04, 2009 | Jabra BT125 Headset
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Lg env2/ jabra vbt85z bluetooth pairing
You will have to go in and reconnect it. When it says allow, be sure to push yes. You may have accidently turned of the internal connection in your phone. Go to bluetooth menu in your phone, click the bluetooth that is yours, and click connect. I did that once, and this fixed my problem. I dont think you can have it paired to more than one phone at a time. It wont know which one to answer. Good luck.
Nov 08, 2008 | Nokia 1600 Cellular Phone
Plantronics bluetooth
you have to first put bluetooth headset in pairing mode by holding the phone hook button down until blue indicator on headset goes solid blue not flashing then set your phone to find bluetooth device by looking under your phones menu and look under bluetooth or connections make sure to turn on bluetooth function and choose find or add device phone will detect bluetooth device and will display the type of device on your phones display tell it to bond or connect once you select yes thats it the bluetooth headset will start to flash and its ready to go.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Motorola Mobility MOTOROKR EM330 Cell Phone Logo
270 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
