Question about Frigidaire FRS-26DR7D Side by Side Refrigerator
Frigidaire fphc2399kf1 cd side by side with temp settings at 3f and 38r freezer temp fluctuates from set point down to -14 and back over several hours continuously. display board, main board, and both senors replaced. pushing the fast freeze button seems to stop it
SOURCE: Motor runs continuously. Frigidaire freezer model
Well in that case or the termostat is defective or is bulb is not well placed. try to see were is the end of the bulb fixed
Posted on Jun 30, 2008
awcforever
  • 359 Answers
SOURCE: Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Posted on Jan 30, 2009
SOURCE: hi i have side by side refrigerator frigidaire
bought a new one.thanks
Posted on May 13, 2009
SOURCE: Frigidaire Refrigerator FRS26H5ASB5 side-by-side
Hi, yes, your thermostat could be faulty, yes there should vent( damper), check controls on freezer side, controls amount of cold air going to ref. side, yes could be stuck by ice, yes both adjustment are necessary, check manual, some thermostat are very sensitive, you should adjust gradually, wait for about 40 minutes, before adjusting again. yes there's vent flap (damper) yes that could be your problem, normally they get stuck with ice, remove covers to locate it., you 're smart, you will see, damper, good luck.
Posted on Aug 12, 2009
woodchuck789
  • 4066 Answers
SOURCE: frigidaire side by sid model
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Sep 03, 2010
Freezer too cold
Is this a model=>FGHC2342LF Sounds like the freezer=> 240597203 Thermistor may be defective??There should be one in the freezer that regulates the temp and this one may be causing the compressor to run continious and you may not be getting the correct reading from freezer. Have you seen this?
Sea Breeze
Jan 06, 2014 | Frigidaire FGHC2342LF Gallery Series...
Frigidaire GLHS269ZCB4 after power outage Freezer not cooling fridge warmer hear the fan click and short cycle
Hello Wayne, thank you for allowing me to assist you. Was the freezer unplugged during the power outage? If it was, here are some simple troubleshooting steps you need to take:
It is best to unplug the unit and wait for the power to come back on.
Next, turn the control to off (or digital display), plug the unit in and reset control to factory-suggested setting.
Do not open freezer door unnecessarily if freezer is off for several hours. Make sure the refrigerator plug is tightly pushed into electrical outlet and not plugged into a GFI.
If your unit has no power and it is not due to a power outage, check the following:
Verify that the temperature control is set to the OFF position.
Set temperature controls to proper setting suggested by your owner's guide; or set to the halfway point and adjust it up or down as needed.
If these basic troubleshooting tips prove ineffective, the power loss may have possibly caused a communication problem with the control board, temperature control or wiring harness. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Aug 23, 2013 | Frigidaire FRS26KR4A Side by Side...
I hear water running in my freezer and can see it dripping inside the freezer through the grate in the back panel. As this is happening the freezer will warm up to almost 32 degrees. I have to press the...
they are no longer 6 or 8 hour timers they are adaptive defrost and the more you open and close the door and the moreyouchange the settings the more often it will go into defrost. There is no set time on these models for the defrost cycle.
Jun 06, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Why does the freezer portion temp indicator bounces between 0 and -12 degrees periodically.
Temps should fluctuate, as the refrigerator will go into a defrost mode every so often. Some models will go into defrost mode after you open the freezer door X amount of times, say 6. So every 6th time you open the door it will go into defrost. Then some models go every 4 to 6 hours depending on settings. Then also, it is normal due to temp control. Temp setting is -10 The fridge will run to that temp setting, -10 and shut off the compressor at -10 but due to pressures it will still cool a bit to your -12. it will stay in this off mode until the temp rises 8 to 10 degs. then kicks back on the compressor. Again due to pressures it may take the system 2 - 3 degs to catch back up and start cooling again. But you maintain average temp of -5 to -6 which is great for frozen food and saves a bit of electricity. As long as the door seals are in good shape and you clean the coils underneath once twice a year it should work fine for many years. Then lastly It may have a lag in the thermostat meaning it has gotten week or going bad. Hope this helps.
Jan 10, 2011 | Frigidaire FRS3R5EMB Side by Side...
Fridgde shut down. freezer droppped to 48 degrees and fridge at 68!!!!is it the compressor? Its only a year old!
If it's only a year old then the compressor/sealed system is under warranty. You should have a 5 year warranty. Go to www.frigidaire.com and request service.
Sep 26, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Is it normal for the temp to go negative on the freezer
yes it is normal. average freezer temps fluctuate from (-5) to (+5) °, the fridge fluctuates from 35-4°
Mar 01, 2010 | Frigidaire FRS26R4A Side by Side...
Do the kenmore refridgerators have a daily defrost cycle? If so, how long does it last and what is the temperature fluctuation? The freezer is empty right now, and the temperature fluctuation seem to go...
All refrigeration products have a defrost set point. Most residential units defrost about every six to eighteen hours. This process should take about 30 minutes to 1 hour. The temp goes up so high inside because there is a heating element in the coils to thaw any residual ice. The temp should not exceed about 45 degrees though. If it does the the compressor is signaled to come back on and start cooling again. This is perfectly alright. The time at higher temp is not enough to spoil the food. Hope this helps. Good luck.
Nov 18, 2009 | Kenmore Refrigerators
Freezer temp
Hello I can help with this problem , You can set it to the factory setting thats normaly in the middle , wait 24 hours for temps to equalize and check temp in freezer with an accurate thermometer it should be -10 to +10 deg. Far. to adjust temp move dial up or down only one digit at a time and wait 24 hours on each adjustment until its at a correct temp.
Dec 30, 2008 | Kenmore 53612 / 53614 Side by Side...
Freezer temperature swings
the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
Jun 24, 2017 | GE Freezers
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
166 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
