Question about KitchenAid Ovens
Have a KitchenAid model YKERC607H58, the cook top works but the electric oven will not. When the temp is entered and start button is pushed the electronics click as if everything is normal but there is no heat on either convection or regular heat
  • Phil Alyea Nov 12, 2010
    will check later today
  • KitchenAid Master
  • 19,396 Answers
Hi.
The character befor the last 8 in model is a letter. The model is probably YKERC607HS8.
Since the oven is clicking, then relays are likely working. The relays must be tested reading voltages, or replacing them. Testing on relays can be done at last. The technician can test initially if there is volts at temperature probe and element, that is already an indication that relays worked. For safety reasons it is better if the user does not perform tests that must be done with power on (volts reading).
The appliance can be tested almost entirely using Ohm meter on parts after disconnecting power.
The first part that can be tested is the temperature probe. This is located inside the oven cavity, and it is indicated as part nr.22 in diagram 1 below. Here the part: sensor.
The probe can be tested removing it from cavity and reading Ohms at its terminals. If the probe is good it will read low impedance or zero at room temp. If the probe shows no continuity at room temperature (circuit open), then the part needs replacement.
Other way to test the probe is by jumping its contacts and starting the oven for a short time. If oven starts heating, then the probe was responsible for the problem. The oven can easily blow elements with probe sensor contacts jumped. Testing must be done by a competent person.
When the oven is not baking or broiling, the temperature sensor is often responsible.
If the probe is good, then the elements must be tested. When problem is caused by an element you usually do not loose bot baking and broiling functions at once. If oven is not baking and not broiling, then the elements are unlikely responsible.
Elements must be tested reading impedance. If one of them shows no continuity, then the part must be replaced.
Next step will be checking if there is continuity in wiring between elements and sensor, and between sensor and oven electronic control contacts.
After that the relays and the control board are tested reading voltages. The relay board is placed at the back of the oven on the left hand side watching appliance from front.
The problem causing the symptoms you described is usually the temperature sensor. Test and eventually replace it .
Diagram 1. Click on the picture to enlarge:
Here all parts and diagrams for your model.
Regards.
Ginko.
Posted on Nov 12, 2010
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
Kitchenaid oven KEBC107KSS03 won't heat after cleaning cycle.
I have a kitchenaid oven # KEBC107KSS03. When I set the temp to 400 the buzzer goes off saying the temp has reached the desired temp, the temp is only 250 and will take another 20-30min to reach 400.
thanks for your reply
Aug 25, 2009 | KitchenAid KEBC107 Electric Single Oven
Upper oven not working
thismay be caused by a few issues, either the bake elemnt has gone bad, or a high temp thermo has gone bad not allowing element ot come on.. have to remove the oven from the opening and acces t he rear panel to check either
Nov 25, 2008 | Ovens
Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
New oven won't work
cobrapilot sorry to be the bearer of bad news. Some where in the oven the contacts going to the oven probe are closing. This could be wiring going to the probe missing insulation and hitting the sheet metal, or the probe socket itself closed. I usually see this after the unit is in use, not right after install. Have you tried to cook a roast or such in the probe mode to see if it will work? For the oven may work just fine then. You are correct about your last line, until service resolves this issue, you have just an expensive microwave. Also as a side note, be sure an be there when the tech showes up. They may just try to say we need a part and not actually attempt to fix your unit. I am not sure what area you are in, however try Olson Appliance Service, He has a website, he is authorized Kitchen Aide service and maybe he can help.
Feb 03, 2008 | KitchenAid Architect Series KEMC308KSS...
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Ovens Logo
162 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
