Question about Kenmore 62622 Microwave Oven
My keypad not working for time n other wat will u suggest to do???
  • 863 Answers
Replace the keypad. Call the 1800 # in the back of your owners manual or look the # up online to order the part. If you don't want to fix it yourself you can take it to a microwave shop and have them do it. Microwaves are made cheaply enough now a days to just toss it out with the trash and get a new one.
Posted on Nov 12, 2010
Touchpad not working
please see the next step. and fix it. God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Aug 02, 2012 | Microwave Ovens
R-408HS some buttons dont work
If the unit does this the keypad area may be bad---cheaper in most cases to buy a new unit.
Jun 17, 2012 | Sharp R-408HS Microwave Oven
Hii i have a whirlpool magicook 27g model , all of a sudden its giving a inverted triangle symbol and i am not able to use any of the cookin buttons ...wat to do ?
Something similar (not the same) happened to my 27G . No buttons work but the display gives different readings at different times. This was corrected when some insulation was applied to the ribbon cable which connects the keypad and the main board as it was touching the outer fram.
Jul 20, 2011 | Whirlpool Microwave Ovens
My over the range microwave is not working properly the buttons are not responding. there is any thing can do to fix his problem
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it's still not working, you probably have a bad membrane keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
If the keypad is bad, you may need to replace the control panel frame, which comes with a new keypad.
To order Goldstar / L.G. parts, visit Encompass. You'll probably have to call them at 866-779-5835.
Aug 21, 2010 | LG Over-the-Range Microwave
GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not working
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, your controller or keypad may have moisture on it.
Sep 08, 2008 | Panasonic Microwave Ovens
Emerson microwave 900w
i believe majority of emerson got programmin ERROR intheir KEYPAD.. my emerson microwave got similar issue ..its a brand new one abt few monts old..it started actin weird way ..its keypad wont work..tried many thing unplug it pluge it back in everthing tht necessary..but still keypad is locked..no not the child procted locked..it locked with a digits 00.00 ...sometimes it work sometimes it dont...so no clue wat to do ...
Feb 17, 2008 | Emerson Black Microwave Oven
At times some butons don't work
You may have a bad keypad, which in many cases can be replaced.
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated.
Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation.
I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 10, 2007 | Hotpoint RVM1425 Microwave Oven
Maytag microwave model#mmv500adb
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the hood fan when boiling on the stove top, spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Feb 19, 2007 | Maytag MMV4205 Microwave Oven
Microwave Keypad not working
This model does have a child lock. If it's on, the display will say "LOCKED". It is turned on and off by holding dfown the "0" key for 4-5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Repost if you need more help.
Nov 04, 2006 | LG LMVM1935 Convection/Microwave Oven
Kenmore 62622 Microwave Oven Logo
56 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
