Question about Bosch 11317evs ¾" Elec Vs Hex Demolition Hammer
Tool has power but can not chip, service light on
  • gagandeep178 Nov 25, 2010
    what can i do in this situation
  • Bosch Master
  • 1,815 Answers
The slide contacts of the electric field all these models had often experience here, one of the 4 of them has problems.
Posted on Feb 26, 2016
How do I reset my Epson T200XL ink cartridges?
Resetting the Epson Ink Cartridge Chip With Software A freeware program called SSC Service Utility enables users to download and install software that helps to manage their Epson printer. The software offers several functions, one of which is resetting the ink cartridge chip. Other settings allow users to freeze the internal ink counters or to reset the internal ink counters. It supports over 100 Epson printer models, but some printers may not respond to the commands from the software.
Using a Cartridge Reset Tool A cartridge reset tool is a small plastic piece that fits against the cartridge. The contacts on the reset tool correspond to the contacts on the printer's ink cartridge. When connected to the ink cartridge, the cartridge reset tool indicates the resetting of the ink cartridge with a green LED light. The reset tool is beneficial not just for resetting the chip, but also for allowing the printer to use all of the ink in the cartridge.
Troubleshooting Issues With the Reset Tool
Buyers should be sure to check the description for each reset tool carefully to determine whether they can reset their Epson printer cartridge with the tool. If the wrong cartridge is attempted or the reset tool is simply unable to reset the cartridge, users see either a red LED light or no light at all. In some cases, they simply cannot reset the chip any further. Before disposing of a reset tool, always test it on multiple ink cartridges.
Apr 07, 2016 | Epson Office Equipment & Supplies
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
Error 5b00
Hello, your error is about the ink absorber.
"Ink absorber full Japan:
[5B00]
Others:
[5B01]
P07 The ink absorber
becomes full.
Replace the ink absorber (ink absorber kit), and
reset the ink absorber counter."
This is the way to enter service mode:
"Start the printer in the service mode.
i. With the machine power turned off, while pressing the Stop/Reset button, press and hold
the ON button. (DO NOT release the buttons).
ii. When the Power LED lights in green, while holding the ON button, release the Stop/Reset
button. (DO NOT release the ON button.)
iii. While holding the ON button, press the Stop/Reset button 5 times, and then release both
the ON and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm
and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm
LED.)
iv. When the Power LED lights in green, the machine is ready for the service mode operation
and "0" is displayed on the 7-segment LCD.
2) Start the Service Tool on the connected computer.
i. When a button is clicked in the Service Tool dialog box, that function is performed. During
operation of the selected function, all the Service Tool buttons are dimmed and inactive.
ii When the operation is completed, "A function was finished." is displayed, and another
function can be selected.
iii If a non-supported function is selected, "Error!" is displayed. Click OK in the error message
dialog box to exit the error."
You can use the service tool to reset this error after you have enter service mode.
here is the service tool:
http://www.4shared.com/file/QptYmQTM/ServiceTool_V1074planet.html?
Nov 03, 2013 | Canon PIXMA MP180 All-In-One InkJet...
Resetting waste in absorber code for IP4900
You ink absorber is full
1. Download canon service mode tools v3400 from the net.
2. Set the printer in Service Mode: - power OFF the printer bu Power button. Dont disconnect power cable
- connect the printer by USB cable to the PC.
- press and hold Resume button (red triangle in the red circle) and press Power button
- hold both buttons until power on indicator will light then release resume button (dont release Power button) and press Resume button 5 times
- release all buttons - the printer will blink few times with green light and will then light green constantly. You have put the printer in Service Mode now and you can now run the Service Tool. (If the printer is still blinking by green - you have some other errors in printer and you have to fix them first, because the Service Tool will not work if the printer is not put in service mode - green light is constant)
3. Run the Servicetools V3400.exe program.
4. Select the connected USB port number from USB PORT
5. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
6. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Print EEPROM information to confirm that the value is properly set to the EEPROM.
Jan 18, 2013 | Canon PIXMA Office Equipment & Supplies
I have an ACER SPIRE 3680 2682, is bad, is not running, does not power on. Is not the ac-dc adapter, that one is good. The problem is on the mother board, dc source?, video chip?, other?. Please answer at...
If no lights, no sound then the problem with the Motherboard Power section Problem, like the DC pin is broken or any shorts etc etc. If Power light is On no Display then the problem with the Display video chip, have to reball the Chip or Replace the chip, service center's only fix this type of issue. best of luck
Feb 21, 2011 | Acer Aspire 3680 Laptop
Service error 6502 I can't get past print head alignment in set up wizard
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
May 07, 2010 | Canon PIXMA iX4000 InkJet Photo Printer
Message displayed:- DOWNLOAD STANDBY
Sounds like you are going to need a Canon service tech.
Boot ROM chip (on main controller) is blank and software has to be updated using Canon Support Tool, via the USB port and System Software. There is also an outside chance that the Boot ROM chip is bad or just need to be reseatted (with power off of course).
Oct 20, 2009 | Canon iR 2016i Black and White Copier
How to reset epson stylus cx6600 cartege chip
there is a tool to reset the print counter on epson ink cartridge chips, but this tool can only be obtained when you are an authorised service provider for epson. and even then it is not advised to use it, since resetting these chips can cause damage to your printer's system board, the replacement of which costs almost as much as the price for a new printer of the same model.
Oct 12, 2009 | Epson Stylus CX6600 All-In-One InkJet...
My set is completely dead no power to crt, no high voltage any hi
well if you have no power you are never likely to get it into service mode!
You have more than likely blown the Power board IC chip which requires a service person to change the whole board and ensure it has not compromiseed the video boards and convergence chips as well. This is not DIY type of fix. If lightning was the cause you may be able to claim fusion on your household insurance policy. Speak to your service engineer about this.
Please rate our help to keep thye FREE service online++++Thanks for using FIXYA
Sep 13, 2009 | Toshiba 27AF45 27" TV
Epson R1800 message needs servicing
Go to computer tool stores, and search the tool that have the name " Auto Reset chip" or "cartridge chip" or "resseter chip" for your epson type , example : "resseter chip for epson t10" . this tool is a lot of selling at any computer stores in the world . In my city (Jakarta - Indonesia) in the selling price just -/+ $. 5 , this tool easy to use and will be described by seller.
The tool like this I have long used since 2002 for epson printer c41 sx and c43 sx....
Many ways to overcome the problems, but it's the most practical ways " to Reset Waste Ink Pad Counter of Everything Epson Type"
Aug 14, 2009 | Epson Office Equipment & Supplies
Bosch 11317evs ¾" Elec Vs Hex Demolition Hammer Logo
274 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
