Question about Canon PIXMA MP160 All-In-One InkJet Printer
As i am not using my printer since 3 years now i got work to use i would like to know whether it works or not and also where can i find the drivers of the machine
    President:
  • 942 Answers
Hello
I you want to find the driver of you machine you can download that in manufacturer site. Visit the manufacturer site of your printer. Go to http://www.usa.canon.com/cusa/home search the model of your printer which is (PIXMA MP160 All-In-One InkJet Printer) click on drivers & Support. Select what type of Operating System you used and download driver. Good luck!
Regards PCmania
Posted on Nov 12, 2010
My hp 900 inkjet printer won't power up.
Please check whether your power cable is well fitted in.
Else replace it.
Feb 12, 2013 | HP 900 Inkjet Printer
Scaner error 12 help me mgl
This seems that driver of the scanner might got corrupted and that is why lost its functionality. To get rid of this issue i will advise you to uninstall and then reinstall the driver for the HP scanner and then check whether the issue persist or not. Also if possible the use the uninstaller utility which will help you to remove the older driver completely from then system so that it will not conflict with the new driver. So try this out and let me know whether this is working for you or not.
Mar 06, 2012 | HP LaserJet M1005 Printer
Trying to reinstall printer software from disc. it quits during install. Is it because the computer has Vista and the disc is for Xp? I dont know how it was installed but it worked ok for a year. What do I...
go to the printer manufacturer's website and dnwnload the proper drivers from there. you will have to know if you have a 32 or 64 bit version of vista. to find out, go to "computer>system properties" and it should tell you on that screen whether you need the 32 bit or 64 bit drivers.
Aug 06, 2010 | HP DeskJet 3650 InkJet Printer
Do you have a driver that works with a i9900 printer that can be used in windowes xp mode windowes 7/ 64 bit professional?
I am not sure whether this drivers actually works or not. But this is what i found... (canon i990 printer driver for xp). Open the link and click on the floppy like icon just below the "canon i9900 v1.75a printer driver...."
Good luck.
Thanks for using FixYa.
Jun 16, 2010 | Office Equipment & Supplies
I want driver for windows 7
It seems that Toshiba's latest driver for this device supports only Windows XP and Vista 32-bit.
Here are the links:
1. Scan/Print Driver, Win 2000/XP v2.30
2. Scan/Print Driver for Vista 32 bit
3. Button Manager for Vista 32 bit
Manufacturers usually drop support for older devices after some time. Specially for printers and scanners the support is even more limited; most of them (if not all of them) offer warranty of one year.
Your best shot is to try the Vista drivers. For printing you shouldn't have problems. When you install the printer Windows have generic drivers for supported (current/older) devices. This driver should work for printing.
For scanning you can try something like VueScan which is compatible with Windows 7. Toshiba devices are not in their list of compatible scanners, but you can never know...
Note that VueScan only works with SCSI, USB and Firewire connections, most wireless Canon and HP scanners (on Windows and Mac OS X only) and doesn't work with parallel-port connections.
This can be solved with a parallel to USB cable converter (be sure to check whether you need male or female parallel to male or female USB converter).
I hope this answers your request.
Nakis
Feb 16, 2010 | Toshiba e-STUDIO 120 Laser Printer
Fs-1118mfp not printing over the network
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Network printer win 7
If the driver is already available and you're getting the error "Windows cannot connect to the printer" and "Operation failed with error 0x0000000d" in the detail,
I found a solution from Vista that can be adjusted to work in Windows 7:
1. In "Devices and Printers" click "Add a Printer"
2. Select "Add a local printer"
3. Select "Create a new Port" and use "Local Port" as the Type
4. Enter the Network Path to the Printer (ie. \\ComputerName\SharedPrinterName) as the Port Name
5. Choose the printer from the list
6. Choose whether you want to use the driver that is currently installed or replace it
7. Name the printer
8. Choose whether to share the printer or not
9. Choose whether to set the printer as the default printer or not
Jan 07, 2010 | Kyocera FS-1118MFP Laser Printer
The light is blinking
hi,
1.Please check whether drivers are installed.
2.check whether printer is printing the test page.If not issue with printer.
3.If printing the test page then please reinstall the printer and then check.
Any troubleshooting you followed or any error message Let me know.
Jul 06, 2009 | HP DeskJet 3940 InkJet Photo Printer
My hp lazerjet Series II printer will not work with my new Compaq Presario desktop PC.
please install laser printers driver from cd suppllied with printer then use ur printer. please let me know whether ur problem solve or not...
hero302
May 05, 2008 | Computers & Internet
Shows it's offline
Hi,I was working for HP as Sr. tech support for 18 months in All in One printer Department, newly joined at Fixya to test my technical skills.
Step 1.Unplug the USb and reconnect it.
Step 2.If that doesnt works, right click on the printer ICOn in the control panel ->Printer and faxes.Check whether do u see "use printer Online".If u see it click on it and then check the printer,If it doesnt works or If u dont see the option "Use printer ONLINE".Go to Step 3.
Step 3:
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thank you.
Feb 09, 2008 | HP Deskjet F340 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
16 people viewed this question
old marine
old marine
