Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My Sony KDL-32P3000 shows vertical stripes, and just stripes, nothing else, no picture.
  • 9 more comments
  • joeroc123164 Nov 12, 2010
    You need to pull up the menu screen and see if the lines are also on that screen. After you get back to me I'll point you in the right direction. Joe
  • f_h_m_brouwe Nov 12, 2010
    The buttons give no result, so I cannot see a menu screen, just stripes which stay. It only acts on the power on/off button. (the tv set turns correct on and off). Tnx for helping! Frank
    No sound at all
    Hi Eagle, thanks for you help
    I don't know if you saw my last reaction, so.. no sound at all
    What happened was next:
    At first screen was dark, pictures were double, and slow (fading).
    I brought it to a dealer who said it was a softwareproblem.
    I took my tv back and turned it on, I saw only stripes, nothing else.
    Does a factory reset help?
  • f_h_m_brouwe Nov 15, 2010
    Hi eagle, how much does a replacement cost when I order one from you? Is it easy to replace or should I turn to a professional? (which I'm not).
    Thanks Eagle338, I will consider your advice. Can you give me the link of the store and the name and part# of the board?
  • f_h_m_brouwe Nov 18, 2010
    Yesterday I removed the back cover. I see 2 boards, left a brown boad part# A-1276-472-A and on the right side a green boad for connectors, with a yellow sticker 5.27 B5.
    There is a little metal plate in the middle on the top, with LJ63-04246A. I didn't see a large board. I made a picture of it, can I send it to you by mail?
    http://img824.imageshack.us/g/foto0019m....
  • f_h_m_brouwe Nov 19, 2010
    So you think the green boad is causing troubles? 5.27 B5 is on the yellow sticker on it. There are many numbers on that board, mostly of the parts that are connected to the board, but I will look again. This weekend I will look again and search for boardnumbers.
  • 4,889 Answers
What about sound? Do you have sound?
Posted on Nov 12, 2010
  • 4 more comments
  • eagle338
    eagle338 Nov 12, 2010
    No it won't . This definitely is a problem with the audio/video mainboard of the set. You have to get it replaced. The problem has just got worse with time. You can get a replacement for about 100-125$(refurbished). I can find you one if you want.
  • eagle338
    eagle338 Nov 15, 2010
    Well I do not sell parts , but I can link you to the store from where you cannot get one of them. LIke I said it costs 100-125$ and it is not very hard to replace, but if you do not mind spending an extra 100$ for the tech to replace it(you purchase the board, the techs will charge you around 300-400$ for the board!)
  • eagle338
    I surely will, but you are gonna have ti get me the part number from a label thats on the board, along with any revision version if any. Just want to make sure that you get exactly the same part, so its recommended that we order using the part number thats on the board. If you remove the back cover, you can see it at the center of the set a large board usually covered by a metal plate.
  • eagle338
    eagle338 Nov 18, 2010
    You can just upload the pics to imageshack.us and get me the links.
  • eagle338
    The one in the first 2 images looks like it but 5.27 B5 does not look like a part number. Can you please get me any other numbers off the board so that I can find you the part?
  • eagle338
    eagle338 Nov 19, 2010
    Ok. Sure.
Sony bravia KDL-50W800B got only vertical lines when turn on.
You need to take it to a TV repair service, preferably one that specialises in Sony TV's. There is nothing you can do to fix this yourself.
Jun 16, 2016 | Sony Televison & Video
I have a Sony KDL-32BX300 showing vertical lines. Is this repairable?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 30, 2015 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Sony bravia kdl 46xbr
you must test there poor connection, and particle inserted.in LVSD
SEE THE DIAGRAM attached.
Jul 19, 2013 | Televison & Video
Picture won't refresh on left 1/4 edge of screen
It may and likely is a defect inside the display panel itself.
Jun 16, 2012 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
KDL-40XBR5 has vertical color lines no picture .After 50 minutes picture shows back with right side darker. TV was purchase 2008
It sounds like you might have a defective LCD panel. Your warranty for your TV is 18 months. Some of these models the warranty was mis-printed and said only 12 months.
Sep 08, 2010 | Sony KDL-40XBR5 40 in. LCD HDTV
Sony bravia KDL-40V4100 audio and picture cycling on and off
I'd say about the blinking to a black screen would be your cable provider. As for the stripes that means that your board panels can be going bad, you can try updating the firmware of the TV to help but if that doesn't work you're getting very close to full failure on the TV.
Dec 14, 2009 | Dell E153FP 15" LCD Monitor
The vertical screen cannot be adjusted. Watching football games the score cannot be seen at the top of the screen. changing vertical center and vertical size has no effect
You question shows its Sony KDL-46S2000 lcd tv so adjust screen format like zoom etc to adjust picture size best fits in screen.
Screen format option is available in Menu.
Dec 06, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
How to do a complete factory reset of a Sony Bravia KDL-32P3000
Just talked with Sony Support today.
It seems that Sony in Denmark had sent out new software updates (over DVB-T) but also some wrong TV's got updated as well. This caused my DVB-T tuner to not function anymore so I wanted to try a factory reset and it fixed my problem.
So I was instructed on how to do this. I have a Sony Bravia KDL-32P3000 (which should be similar to the U3000 and S3000 as well).
This is how to do a factory reset of your Sony Bravia KDL-32 P/U/S-3000 TV.
PLEASE BE VERY CAREFUL WITH THE SERVICE MENU, YOU CAN EASILY CAUSE YOUR TV TO MAL-FUNCTION!!!! IF YOU FOLLOW THIS GUIDE IT IS AT YOUR OWN RISK!!!
Set your TV in standy (use the green power butten on your remote), RED standby LED is ON on your TV.
Now press these buttons in this order on your remote (pointing to the TV).
i+
5
VOL UP (+)
GREEN POWER button
NOW BE CAREFUL! Dont press any keys just for the fun of it!!! IT MAY DESTROY YOUR TV.
You should now be in the service menu. It will show up as some green letter/numbers spread over the screen (mine are a bit hard to see/a bit faded). In the upper right corner you should have 2 letters TT (two t's).
Now carefully press key 0 and then key 8 on your remote (they should be shown on the screen after the two TT).
Now wait a little while (more than 10 seconds) and your TV should reset with factory settings, just as if you had just brought it home from the TV store.
Best wishes,
Mads
May 14, 2009 | Sony KDL-32S3000 32 in. LCD Television
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
744 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
