Creda Cascade Ecowash Series Washing Machine. Model 17084E. Machine 14 years old. This is the first fault on the machine. The machine stopped whilst half way through the rinse cycle (40 wash programme), I put it on the long spin, the machine started up and the drum did a few short tumbles then stopped after 10 seconds. I tried it on the short spin and the same thing happened again. I took out the sopping wet clothes and the drum was empty of water. Any ideas? Thanks
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Posted on Feb 15, 2007
  • 1073 Answers
SOURCE: Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Posted on Apr 21, 2008
Krazytech
  • 725 Answers
SOURCE: Hitachi Washing Machine model SAF-2000PX
check the lid switch ... make sure it is make contact and the the actuator is working hope it helps
Posted on Sep 16, 2008
  • 6 Answers
SOURCE: Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: door won't open at end of cycle Creda 1000 ecowash front loader
Hi Jenny. Do you have the model No. available?
Most common cause of this problem is
1. A faulty or broken door catch.
2. A faulty interlock. This is the part that the door closes in to.
Some older models have other devices that will prevent machine opening if it has not pumped out fully, or mechanical devices that check for drum rotation that can be knocked during the spin. Could really do with age and model No. of machine.
Posted on Apr 04, 2009
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
I purchased this machine last year now after ending the programme i.e.washing door is not opening and it is showing error 14. Could u please help me out. Regards
Hi.
The fault E14 on Hoover washers indicate a problem with the heating circuit. Element, Thermistor and Central Control unit must be tested.
About error codes and troubleshooting Hoover appliances see the links below:
Hoover After Sales Service - Online Fault Finder
(Hotpoint/Creda/Indesit/Ariston Error Codes)
If you need parts or diagrams see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
The sellers apply to USA market. Elsewhere see your local hoover distributor.
If you need to call a technician ring the customer service number listed on the owner manual or check your local Hoover website.
Regards.
Ginko
Sep 15, 2011 | Hoover Washing Machines
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
Water not draining from the drum and no filter in evidence
Remove rear panel of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Aug 15, 2009 | Creda W100FW Front Load Washer
Door won't open at end of cycle Creda 1000 ecowash front loader
Apr 04, 2009 | Creda W100FW Front Load Washer
Where is the filter
The filter is located at the rear`of the washer.
To access it, remove the rear lower panel.
You will see a large black hose, remove hose from bottom of tub, and you will find the plastic filter inside, remove filter and clean.
Refit filter and hose, and test.
If it still does not spin, then you need to check the brushes.
If you require info on how to check and change them, then let me know.
Please rate my fixya solution.
Thanks.
THanks.
Feb 10, 2009 | Creda W100FW Front Load Washer
Creda eco washing machine won't spin
It sounds like it needs new carbons fitting in the motor.
It is a fairly straightforward repair.
Remove the top cover, screws at rear, and slide top cover off towards the rear.
The motor is located at the top right right rear, you will see the drive belt.
Slacken the bolt that holds the motor, and push the motor down towards the top of the drum.
You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic`lug that holds the brushes in place, slide the brushes out of the motor.
fit new genuine Hotpoint carbons, and follow instructions on packaging. Push the leads back on to the carbon terminals.
Tighten up motor, and make sure the belt is reasonably tight.
Job done.
Test on final spin before you refit top cover.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Washing Machines
Creda plan Integrated Dishwasher fault
door latch is in wrong position, split the door so you can see whats what and change the position of the switch
May 16, 2007 | Creda 24 in. DWI34 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
