Question about Whirlpool Refrigerators
I need a fridge freezer front door shelf for a KGIF 3268 (Service No 855068701010-110121004525). I live in The Hague NL. Where can I get the part? Thanks, William
  • 4,793 Answers
Whirlpool.com.......or espares.co.uk.they keep the vast majority of bits.
Posted on Nov 12, 2010
My Samsung Refrigerator side by side door ,,Model,,SRS583DHD,, left hand side door ice maker increases temp and not producing ice,,;-(,,Bot
Your description sounds like a loss of air flow problem. Check for overloading your freezer and fresh food side. In order for the freezer and fresh food side to work properly, the air vents need adequate room for air to circulate. I had a customer who completey filled the middle shelf with cardboard boxes and completely blocked air flow on the middle shelf The lower level near the evaporator was extremely cold and the upper area was room temperature in the freezer. Each shelf needs about an inch of room at the back and room between packaging to allow air to circulate.
Hope this helps
Dec 13, 2014 | Refrigerators
Freezer was thawed out and now the door won't close
please check the way you installed shelves and the way food is stored. Remove food and shelf and reassemble. It should fix your problem.
Make sure the fridge level so front is raised so doors swings close after you had open them
Aug 26, 2014 | Refrigerators
MFD2560HEW Bottom freezer french doors. Top shelf in fridge is 52.2 degrees 2nd shelf is 45.7 degrees 3rd shelf is 38.5 degrees and the bottom shelf that slides out that sits above the freezer is freezing...
At this point I am not sure if your Auto Damper that regulates the cold air is stuck closed or if the thermistor that controls the damper is responsible. You could also be having a defrost problem restricting the air flow to the fresh food section. Look into rear of freezer to see if there is a layer of frost building on rear panel. If yes then we will need to focus in a different direction. First by manually unplugging fridge and then using a hair dryer to help speed things up. The manual also has diagnostics test that you can do to locate a problem area like thermistors or many other errors will show once placed into diagnostics. Sea Breeze
Jun 03, 2010 | Maytag MFD2560HES Bottom Freezer French...
My fridge is not cold, but the freezer on the top shelf works perfect. What should I do?
Since the freezer has the greatest demand for cooling, there is a fan which distributes some of the cold air through the fridge; this fan has likely failed.
When you hear the compressor running, hold your hand inside the fridge near vents in the back of the upper shelf. If you feel no air circulating, the fan is bad.
Not knowing your unit, I'm not sure how you access the fan motor, it could be from the back or from inside one or the other compartment.
The fans are not expensive but the labor can vary a bunch depending on how tough it is to access the fan and the area in which you live. I would call their service center after you have checked as described and state that the fan has failed and needs replacement. Ask them for a quote or at least a 'not to exceed' price.
Mar 18, 2010 | Haier HTE18WAA Top Freezer Refrigerator
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I have an extreme amount of condensation appearing in my new frigidaire. my shelves are wet and the food at back of my top shelf has frost. (i live in los angeles, not too sure if that at all factors into...
If it's new I would think the door gasket is ok but that's one thing that could cause it.
The air has to circulate by way of a vent between the freezer and fridge. Make sure the vent door is opening when you adjust the fridge temp.
To complete the circulation the freezer fan behind the back panel inside the freezer must work and the evaporator coils near the fan must not be iced up blocking the air flow. (defrost failure.)
Aug 09, 2009 | Frigidaire FRT17G4B Top Freezer...
Freezer door needs to be raised
just put some washers (plastic washers are best) on the hinge pin to raise the door
Nov 16, 2008 | Whirlpool ET0WSRXML Top Freezer...
Refrigerators Logo
44 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
