WASHER KEEPS AGITATING WHILE SPINNING - Washing Machines
  • Phillip Brickhouse Nov 17, 2010
    Had to buy new washer, clothes were backing up before I could find out what was wrong with the old one.By the way the old washer was a whirlpool LSR7233OQR
    Top Expert:
  • Washing Mach... Master
  • 78,936 Answers
Hello
In order to try and provide any assistance I will need the make and the model number of the washer as well as any other useful information or repairs you may have attempted. Thanks
Posted on Nov 12, 2010
  • yadayada
    yadayada Nov 17, 2010
    This was most likely a washer cycle timer problem, but no matter since you replaced it.
Washer not spinning
If you are neither spinning nor agitating and you can hear the motor running (humming or buzzing) the the problem is with the coupling. See the first link below to repair.
If the motor does not run, only fills, no drain, no buzz no hum then the problem is most likely with the lid switch, see the second link.There is video near the bottom of that page showing how to replace it. Let me know if this helps.
Coupling
Lid Switch
May 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Not spinning or agitating
Most likely you have a bad belt or a defective lid switch.
Mar 07, 2010 | GE WBSR3140DW Top Load Washer
What is the part that starts the wash cycle when the lid closes'
I assume that you mean the Lid Switch which keeps the washer from draining and spinning (in older models) and agitating, draining and spinning (in newer models) unless the lid is closed.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the cabinet and / or console and you should see it.
Nov 11, 2009 | Kenmore 22422 Top Load Washer
Simpson washer 22S950 not spinning..not agitating..water pump works...L6 come on the screen...bipps most of the time...part of numbers missing on the screen..
simpson washer 22S950 not spinning..not agitating..water pump works...L6 come on the screen...bipps most of the time...part of numbers missing on the screen..
Jun 22, 2009 | Washing Machines
Washer not agitating/spinning
chances are that this would be a worn out coupling.
easy to install for someone who is partly inclined.
part costs about 15$ and takes about 20 minutes to install.
May 27, 2009 | Kenmore Washing Machines
Avanti spinning problem
One of the largest problems with this washer has been the lid switch, you must check it out with a ohm meter, if the switch quits you will lose power to the motor. Things can get caught between the tanks as well, this machine is bad for the center bearing tightening up and the spin will quit. This is a new close up pictureof a typical lid switch. You can temporarily join the wires together to test the motor and washer operations.
Apr 03, 2009 | Avanti W789SA Top Load Washer
No spinning or agitating
If it has a mechanical timer switch, (the main control knob) that is possibly the culprit. The timer switch is basically the "brain" of this type of washer. I had this problem on a washer.
Dec 26, 2008 | Kenmore 24032\24036 Top Load Washer
Amana washer not agitating and does not spin all the time
"Its not spinning well" that means it is spinning but at a relatively low speed .....if this is so try having the motor serviced.....or replaced.......also have the capacitor checked...
Nov 10, 2008 | Maytag PAV2300 Top Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Open Questions:
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
