Question about Dishwashers
I have a Flavel dishwasher, model no. DWFA20S. When the cycle is set and running, the dishwasher shuts down completely for a few seconds and then restarts. I'm worried about its safety?
bigg t
  • 640 Answers
SOURCE: Kenmore model 665 dishwasher
the timer is bad.the 42 min cycle and the 6 min cycle share the same timeline.try northernparts.com for the part number and price.installing the timer isnt that difficult.
Posted on Jan 05, 2008
SOURCE: Maytag dishwasher MDB9100A---tub refills after cycle completed
Problem is actually a water valve that is near the water inlet. Cost is about 35 bucks to fix unless you listen to the guy on here and pay for parts that you don't need and pay them 20bucks for bad advice. Our total cost to fix this $35 dollar problem was an entire wasted Sat, 2 trips to the appliance repair parts place, $130 for the electrical control board that the "wiz" here said I needed--electronic parts and non returnable so we now have a new one that we didn't need.
Posted on Mar 30, 2008
SOURCE: Kitchenaid Superba Dishwasher - Restarts wash cycle
sounds like bad console or bad control board.
Posted on Nov 04, 2008
rockfixya
  • 679 Answers
SOURCE: Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Posted on Jan 03, 2009
subarufamily
  • 6 Answers
SOURCE: dishwasher fills cycle runs for a few seconds and then it stops and motor growls
Check for a deformed shaft on the water level float. Remove the kick plate and look for where the shaft of the float touches a micro switch. Often the shaft is bent sideways and only engaging the micro switch indirectly. Straighten by hand for a temporary fix or reinforce the shaft with aluminum tape and sewing needle. Keep the retrofit light weight to avoid problems with water overflow.
Its also possible you may have debris clogging the check valve that keeps water in the tub during certain cycles. To find the checl valve you'll need to remove the lower rack and completely disassemble the central assembly from the top down. If you are mechanicaly inclined its not hard. If you are worried about proper re-assembly, then video tape the disassembly as a memory aid and stack the parts and screws in careful succession.
Once you reach the steel garburator blade you only have one more plastic plate to remove. Examine both ports on the plate to ensure that there is no jam or debris. Throughout the disassembly, look for any broken glass or debris that could be jamming or clogging.
If neither of the above problems is found then the other possibility is a deflective or melted down circuit board. Check your owner's manual for longer warrantees on the control panel. A long time ago they use to have 3 - 5 year warranty. More recently the warrantees have been only for one year. Check your owner’s manual because if you ask the call centre they will always say one year even if the warrantee is longer. If the part is covered then disassemble the door to get at the control panel. Look for signs of melting/overheating. If the unit is out of warrantee then replace the dishwasher. The control panels cost as much as the dishwasher. Replace your Maytag with a quality brand like Miele. Avoid, Maytag, Jennair, Kitchen Aid, Whirlpool, Kenmore, White Westinghouse. They are all made by the same umbrella company with the same crappy parts, poor reliability, poor cleaning results and short term warrantees.
Use to be you could get 10 – 20 years of service from a North American brand. These days 3 – six months of clean dishes as much as many customers can expect before dishes become progressively more and more disgusting. Poor engineering is responsible because the designs are prone to jams, clogs, water level malfunctions and circuit board failures.
Posted on Jan 27, 2009
Dishwasher took 3 hours to complete cycle
If you have set the unit to heated water or your hot water is not hot will delay the wash cycle. The heater in the dishwasher is very slow!
The following is from the user manual.
15
TROUBLESHOOTING
First try the solutions suggested here and possibly avoid
the cost of a service call...
Dishwasher is not operating properly
Dishwasher does not run or stops during a cycle
Is the door closed tightly and latched?
Is the right cycle selected? Refer to the "Cycle Selection
Charts."
Is there power to the dishwasher? Has a household fuse
blown or circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shut-off valve (if installed) turned on?
Dishwasher will not fill
Is the overfill protection float able to move up and down
freely? Press down to release.
Dishwasher seems to run too long
Is the water supplied to the dishwasher hot enough? The
dishwasher runs longer while heating water. Refer to the
"Dishwasher Efficiency Tips" section.
A delay automatically occurs in some wash and rinse cycles
until the water reaches the proper temperatur
Hope this helps?
http://www.repairclinic.com/UserManual/f75a81f2957b4b86b396c8c3629d9078/8531130/Use-Care-Guides-Owners-Manual/Use-and-Care-Guide-8531130
Oct 16, 2016 | KitchenAid Dishwashers
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
On off button does not alway work when cycle complete
You might want to check your owner's manual, Gail. The dishwasher may be completing a "cool down" cycle.
If that's not what's happening, then I suspect the control electronics rather than the button itself.
Jul 30, 2014 | Bosch Dishwashers
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
HI I AM [FED FED} UP WASHING MY DISHES BY HAND DONE A CONTINUIETY TEST ON MY FLAVEL DWFA20S AND THE ELEMENT SEEMS TO BE WORKING THERE IS NO POWER GOING TO THE ELEMENT CAN A NY BODY HELP HELP FROM A...
1). check the house fuse or breaker for the dish washer.
2). turn on the washer by closing and lock the washer door.
3). reselect desire washer setting.
if it still have no electric to the washer. you need to trace the wire from the back of the washer to the breaker panel. if that is no something you can do,then you need to get an electrician.
Apr 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
105 people viewed this question
Top Dishwashers Experts
Owen Barnes
