Question about Vtech i5866 Cordless Phone
I purchased a VTech DS311-2 handset.When i plugged it for the first time i got light on the charging base,after 2 minutes it went off.what to do now?i plugged it for for than 4hrs now.....did all kinds of trobleshooting.still no use.im using 220v .....
SOURCE: Not Registered
I had the same problem and this procedure fixes it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Posted on Jun 01, 2007
  • 3 Answers
SOURCE: Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Posted on Nov 21, 2007
AlmostBob
  • 550 Answers
SOURCE: Vtech ia5870 dual handsets model problem:
http://www.vtechcanada.com/manuals/5870ciben.pdf
from the troubleshooting section of the manual
• Unplug the base unit’s electrical power and remove the battery from the handset. Wait for 15 seconds then plug in the battery place the handset in the base unit and plug in the power. Allow up to one minute for the cordless handset and base to synchronize
not a guarantee, something to try
Posted on Aug 30, 2008
  • 47 Answers
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Posted on Jan 06, 2009
SOURCE: we are having similar problem with vtech 5808
Install new batteries! Be sure to let them charge fully (overnite) before first use.
I have 5 of the i5808 expansion phones around my house - most about the same age - and they all started acting up ithin a few months of each other. I "experimented" with a new battery for one, and it solved the issue for that one phone...so I replaced the batteries in each of the others that were experiencing the problems. This was about 2 to 3 months ago, and all phones have been problem-free since the new battery installs!
Hope this helps.
Posted on Feb 01, 2009
How to register the extra cordless handset of vtech 15250
Add and register a handset
Each newly purchased handset must be registered to the telephone base before use. When first purchased, each expansion handset shows NOT REGISTERED.
You may need to charge the phone first.
To register a handset:
    ·Place the unregistered handset in the telephone base or charger. Press Find for 4 seconds. If the headset screen doesn't light up after the 4 seconds. You will need to charge it some more.
    ·After making sure it is charged set the telephone on the main base again press and hold the Find button for 4 seconds ( until the red light IN USE comes on) Then release the find button. The headset will show PLEASE WAIT; this takes about 10 seconds to complete the registration. The hand set will show HEADSET REGISTERED and the headset number assigned, you will hear a beep when the registration is finished
    ·When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset is HANDSET 3.
    ·Makes sure no other headsets are in use at the time or the registration may fail.
    ·You cannot register a handset if any other system handset is in use. Only one handset can be registered at a time.
Aug 18, 2017 | Vtech Lands Phones
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
I have a three handset 6.0 v tech. the one handset keeps beeping. What is going on?
With vtech phone (many times) a beeping handset indicates a low battery or an inability to connect to base station. check to make sure the battery is connected correctly and that the phone is setting in its docking station correctly. (remover and obstructions that would prevent correct charging) If this fails go to your local store that sells batteries for cordless phones and purchase to correct type.
Oct 13, 2010 | Vtech 5.8 Ghz Handset Cordless Phone...
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
How do i sync my vtech CS5111 to its base...please help...
have the main based plugged into a working ac outlet and active telephone line then place phone on base for 1 minute then remove base should sync within that time
Mar 18, 2010 | Vtech Lands Phones
One of my vtech 5867 handsets is frozen. It is stuck on one caller id. Battery is charged. What to do?
Have you tried re-establishing connection with the base unit? Try setting it on the base and wait for the charge light to blink a couple of times and re-connect the handset and see if that helps.
Dec 23, 2009 | Vtech 5867 Cordless Phone
Is there a reset button anywhere on a vtech cordless phone?
remove battery for handset.
unplug power AND phone line to base unit.
wait 15 seconds or more.
reinstall battery.
plug in power to base.
plug in phone line to base.
put handset in base charger slot.
wait a minute or more for all to reload from ROM.
Oct 14, 2009 | Vtech Lands Phones
Aug 30, 2008 | Vtech ia5870 Analog Cordless Phone
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
Mar 20, 2007 | Vtech i5808 Cordless Expansion Handset
Vtech i5866 Cordless Phone Logo
52 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
