Go into your menu and find 'Call Log' there will be an option for 'erase all call data. As for sent messages, go to your 'sentbox' folder and find 'delete all'. This will delete the call history and any records of messages sent.
Alternatively, to perform a full factory reset (THIS WILL ERASE ALL YOUR CONTACTS AND RESET THE PHONE TO BEFORE FIRST USE!) :
Press ##786# then select 'Reset'. Password would be your MSL, which your provider has (call customer care for your MSL). This is a factory reset, this will reset everything.
To erase the recent recipients list, you must do a master reset of the phone. This will erase all texts, alarms, and any other personal settings you set on the phone, but it will erase your recent recipients. This is the ONLY reliable method I found
This is a common problem with outlook express. The files have become too large for outlook express. I recommend blowing out all the emails. Try first empty the deleted items. If it will not delete. You need to find the folder associated with this identity. That would be in C drive then documents and settings then your username then application data (hidden folder) then identities. There will be a folder with a crazy name of numbers and letters. Go into this folder and you will see your inbox folder and outbox, sent box etc. Delete the folders that you dont have important emails in and this will dump that whole box. Make sure outlook express is closed when you do this. When you reopen outlook express it will recreate these folders empty. If you have any questions please feel free to contact me.
Click on messaging icon from main menu.
Click send message.
Instead of clicking text message click on pic/video message.
then you have 4 options TO: CONTACTS , TO Mobile#, To Email, And finally To Recent lict. Click on recent list and checkmark all the numbers you want deleted then click options bottom right corner then click delete.....
All finished hope this helps.
you just go to "send message" option, then select "picture mail", then go to "recent list", click OK, then select the person you want to delete and click on "options" and click on "delete". It will then delete that person from your recent list. I just did this and it works.
Go to the messaging menu choose send message then go to Voice SMS or Picture Mail, okay then choose Recent List there you should see the recent contact you have texted to select the ones you want to delete and press options there you can delete the selected or delete all.
Presumably you had the same problem as i did, you cannot remove the recent contacts from the message thing,
Here is how i resolved it, it takes a bit of messing around but its the only way as far as i know.
Their are 30 recent contacts in that annoying little folder, send a blank text to 001 (but as soon as you send it, cancel it), then repeat 30 times to the respective numbers EG; 001, 002, 003 .................. until you get to 030. (you don't have to use these numbers but its the easiest way)
When i done it, i received a message stating the number i was dialing was to short. (just ignore it)
in the end, you will end up with 030 at the top and 001 at the bottom, but at least you won't end up with any of your private numbers stuck in the recent contacts folder. once you've done that, all you'll have to do is delete the unsent, blank messages.
just text a few different people until the contact is no longer a "recent" conacts, i thinks its like the last so many contacts in the list, i'd check mine but my screens just broke
I am having the same problem. I just contacted my wireless provider and they were stomped!! They tried calling Samsung directly but they are closed on Sunday's. I will be calling tomorrow but I have a strong suspicion that because there is no prompt to delete the log that a "Master Rest" will have to occur. Be advised that if this is done, that log may be deleted but so sill EVERYTHING else that is not factory set. All data will be lost if that is done. So hopefully that won't have to occur.
Unable to delete recent contacts.
