Question about Janome Harmony 2039 Mechanical Sewing Machine
Ive got a jarome new home 314 sewing machine and having problems to get it to stitch but unsure if i have threaded machine correctly, any advice or assistance??
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
bargainbox
  • 1388 Answers
SOURCE: My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 25, 2008
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
mallow1
  • 35 Answers
SOURCE: Thread tension?
I own this little gem of a machine. It definitely sews a perfect stitch. I'm assuming you own the green 3/4 size machine as denoted by your product number. The half size blue one pictured is incorrect.
Anyway, this machine sews a perfect stitch, due to the oscillating bobbin. Most sewing machines with rotary (drop in) bobbins don't have an easily accessible bobbin tension screw, which means your fabric is usually slightly puckered. Fiddling with only the upper tension helps very little. This frustrates me to no end for sewing long curtains, clothing side seams, etc. Wrong tension causes them to hang with puckers, making them look awful. With the Hello Kitty 3/4 size Janome, there is a screw on the bobbin case which allows you to adjust for every thread diameter perfectly. Always a perfect stitch, if you take the time to adjust this screw.
To adjust the bobbin for a perfect tension, load the bobbin into the bobbin case and thread it through the guide. Holding only the thread between two or three fingers, let the bobbin case dangle below. This will be slightly difficult, because the bobbin will want to fall out of the case. Don't worry, just don't move it around too much and it will stay in long enough for this test. If the metal bobbin case slowly drops lower, unwinding thread as it goes, the thread is too loose. Tighten the screw on the side of the bobbin case a little (about a quarter turn.)
If the bobbin case seems to be dangling firmly, give the thread a gentle tug, lifting up fairly quickly. If it doesn't release a couple of inches of thread, it's too tight, loosen the screw. You know the tension is perfect when a quick, light tug of the thread releases a couple of inches of thread.
Posted on Aug 16, 2008
Mongo32
  • 111 Answers
SOURCE: my machine is not stitching
needle in backwards?
Posted on Jun 13, 2009
Hi. I have a Necchi MOD559. For some reason the stitches on the bottom stay too loose, so that I get little string hooks and not a clean tight stitch. From the top it looks great. Advice anyone?
Yep, It is called bird nesting or thread nesting. The number one reason is that the top thread is not seated completely in the top tension disk.
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Confirm the thread path is correct.
Now recheck your machine stitching.
Remember if the thread issue shows under the fabric, it is a top thread problem. If the thread issue shows on top of the fabric, it is a bobbin problem.
If the top thread still shows on the underside of the fabric, you may need to tighten the top thread so it will pull the bobbin thread up.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
May 24, 2017 | Necchi Sewing Machines
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
When sewing it skips stitches also the thread keeps breaking.
Remove the thread from the machine.
RAISE the presser foot and rethread the top thread.
Load and thread the bobbin case & install it. Verify it is correct.
Set the top tension at the midway point.
Re-test your stitch.
Sewing Machine Problem 1 Thread Breakage
10 reasons for skipped stitches
Mar 22, 2017 | Sewing Machines
My New Home L372 sewing machine is dropping stitches
skipped stitches
1. the needle is incorrectly inserted into the needle holder
2. the needle bent or blunt
3. Machine is not threaded properly, rethread using every thread guide
4. Wrong needle for the fabric being sewed
Mar 22, 2016 | New Home Sewing Machines
Singer ce100 is skipping stitches when needle is in center position
You don't say what you are sewing so I'm going to give you general answers in hopes it helps.
1. Needles: There is no such thing as a universal needle. Make sure you are using the proper needle for your fabric. This goes for thread too... make sure it's sized for the needle.
2. Make sure the bobbin is threaded correctly (poorly wound bobbins will cause problems too)
3 Improperly threaded machine. Make sure you area threading it correctly with the foot in the UP position.
4. If you are a material puller... shop it. It is never good to pull your fabric through the machine as you sew.
5. Stitch length. simple rule: Fat fabric.. long stitch, fine/thin fabric short stitch.
I'm not familiar with your futura abut I've noticed new home machines take a way presser foot pressure adjustments... which can cause issues too.
Mar 13, 2013 | Singer CE-100 Futura Computerized Sewing...
Janome tension problem: skips stitches and breaks the thread.
Is the thread and b
needle correct for the material sewn? Otherwise the dealer or manufacturer is the best bet.
May 01, 2017 | Sewing Machines
Won't sew! Loads of top thread bundles up around bobbin casing.
First... make sure you are threading it correctly. It MUST be threaded with the foot up.
Do a test seam. Make sure you put the presser foot DOWN when you sew.
Make sure you grasp and hold the bobbin and top threads as you begin the seam. (this is good practice for any seamstress on any machine.
If you still get loops, tighten top tension.
Also check the bobbin case for burrs. drag a finger nail along edges to feel for it catching. If you find one take a small bit of extra fine sand paper and file it off.
Good luck
Nov 12, 2012 | Sewing Machines
My New Home skips stitches. I have cleaned it, changed needles, adjusted the tension and tried different bobbins .
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
it's also possible that the machine could be slightly out of time
Aug 29, 2012 | Sewing Machines
Janome Harmony 2039 Mechanical Sewing Machine Logo
194 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
