Question about Singer 5062 Mechanical Sewing Machine
I can't fix the tension on the machine Singer 5062. I am getting loops on the bottom
    Genius:
  • 1,788 Answers
Try this little trick, rethread it and then with the presser foot up pull on the top thread, it should move smoothly, now put the presser foot down, the thread should barely move. This sometimes seats the thread in the tension discs the right way. I have my tension set at 3 but each machine is different.
Posted on Nov 12, 2010
Singer 328K is jamming.
Most likely there are jamming threads at bobbin room under the machine stepping pedal, try to dismantle it to get rid of these threads.
Sep 22, 2017 | Singer Sewing Machines
Singer 160 bottom tension problems
tighten the little screw on the bobbin carrier... a little at a time.
are you sure it's the bottom tension? Loose top tension will make loops on the bottom side of the seam.
Sep 03, 2012 | Singer Sewing Machines
The bobbin will not wind properly - it bunches at the bottom and will not "thread" from top to bottom for proper tension
Mine did same thing,was told to wrap twice around the silver know where you normally wrap twice,make sure bobbin is all the way down.dont forget you start threading as if you were going to for top thread go thru first hook then over to silver know,but twice.hope this helps did me
Jul 08, 2011 | Singer 5062 Mechanical Sewing Machine
I have a singer 5062 that was given to me and I am not sure how to thread it. Also I would like to download a manual if possible. My top stitch looks good but the bottom thread keeps looping up and looks...
Go to http://www.singerco.com/accessories/instruction-manuals and enter 5062 into the search field. You can download your manual for free in Adobe Reader format. That should have instructions on how to thread.
It also sounds like your tension needs to be adjusted. Let me give you instructions for adjusting the tension on anysewing machine. Be sure to have a scrap piece of the fabric you are using andthread the top of the machine with a different color of thread than thebobbin-it'll make it easier to see what's going on. Thread your machine with the presser foot UP. The disks that control the tension (threadgoes through them) are tightened up if the foot is down. Change the machine tension with the presser foot DOWN.Because the disks won't be engaged (see above) if the foot is up, the diskswon't move. Start at the middle setting, 3. Go up to tighten, decrease toloosen. Each machine is different, even 2 different machines of the same model.The best thing to do is start at 3 and use a different color in the top andbobbin thread so you can easily see what changes to the tension do to yourstitches. Now use a straight stitch a sew 3 or so inches. Take a lookat the top and bottom of the fabric. You don't want to see any (or at least notmuch) of the other color showing from the other side. Loops on the bottom of the fabric means you need to tighten(increase) your top tension. If you're stitches on the bottom are causingpuckering, then you need to loosen you're top tension. For the most part, youreally don't want to touch your bobbin tension-leave that to a repairtechnician. The factory setting shouldn't be touched except by someone whoreally knows what they're doing. Keep sewing a few inches at a time until you have the resultsyou want. Now you're tension is where you need it!
Jun 25, 2011 | Singer 5062 Mechanical Sewing Machine
Looking for sewing machine manual for singer sewing machine model 6218. The bottom bobbin tension is so loose that it forms many loops under the fabric.
I went to the singer website & typed the number in 6218 & it came up with nothing, is that the correct model number?
the tension problem try adjusting the top thread tension to 3-5, & see if that helps the loose tension
Oct 21, 2010 | Singer Sewing Machines
My machine is not computerized. How do you fix
If the loops are on the bottom it means either the top tension is too loose or the lower tension is too tight. It can also mean that the thread is snagging on something in the bobbin case area.
sewman7
Apr 24, 2009 | Singer CE-100 Futura Computerized Sewing...
Top tension adjustment
Believe it or not, most computerized machines have an automatic tension. This works well providing, the thread is thru the tension wheel setup.
But for further reference,
loops on the bottom-- problem on the top.
loops on the top--problem on the bottom.
Mimi
Apr 23, 2009 | Singer CE-100 Futura Computerized Sewing...
Upper thread balls up on the bottom. Makes a matt on the underside of garment.
If your thread messes up on the bottom then the problem lie in the top threadinbg of the machine.. Some how it is not thru the tension wheel like it needs to be. FYI.. Loops on the bottom fix the top.. Loops on the top, fix the bobbin.
Apr 19, 2009 | Singer Sewing Machines
Loose stitches on bottom
FYI.. Loops on the bottom, problem is on the top..
Loops on the top, broblem is with the bobbin.
Apr 11, 2009 | Singer Sewing Machines
No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
Apr 10, 2009 | Singer Sewing Machines
Singer 5062 Mechanical Sewing Machine Logo
105 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
