Question about Acer Aspire 5500 5570-2609 Laptop
The problem is we have an acer aspire 5551-2384 and in order to get our @ sign up we have to push two keys is this correct cause we have used other computers and have never had to do this can we change this thank-you
Hi, am trying to set my laptop to factory set but seems to work without recovery disc
Posted on Mar 13, 2011
Set key board to US standard
Posted on Jan 01, 2011
WHen using the shift key to type the at sign or the esclamation mark etc it does numbers
Is this the only problem with the keyboard not getting uppercase to work ?
While Acer laptops are built to be used on the go, they are not indestructible. An accidental drop or even normal wear and tear over an extended period of time can cause the laptop keys to become dislodged and fall out. Debris can also build up inside the keys and make them stick or stop working. Fixing the keys on your Acer laptop is a quick process that does not require taking the unit to a professional repair shop.
Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop. Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole. Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole. Set the key back onto the plastic clip. Push the key down until it clicks into place. Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen. Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop. Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air. Reassemble the keyboard, LED indicator strip and battery.
Acer aspire keyboard removal http://www.cyfinity.com/2008/07/acer-aspire-5315-keyboard-removal/
Mar 01, 2013 | Acer Aspire Computers & Internet
My boot priority order changed now my computer wont go to my desktop
Hi!
Sorry, I hope I was not too late. You can fix priority order issue by restoring the default value of BIOS. You can do that by doing the steps below:
1. Reboot your Acer Aspire 5315 notebook.
2. Wait about 30 seconds until you see the Acer logo on your laptop screen.
3. Press the "F2" key on the keyboard to enter the Acer Aspire 5315 laptop BIOS menu.
4. Select the BIOS option "Load Default Setting" using the arrow keys on your keyboard. Then press "Enter."
5. Press the "F10" key to save the BIOS that is reset to the factory default settings.
Hope this helps.
Apr 16, 2011 | Acer Aspire 5315 Notebook
It displays the following message windows faild to restart. a recent hardweare or softweare m.ight be cause . to fix the problem:
In order to recover the Operating System using Acer Recovery Media please perform the following:
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the Acer Recovery Media, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media they may be purchased at our online Acer order form..
Oct 31, 2010 | Acer Aspire 5610-4648 Notebook
I have Aspire 5536-5519 and on the keyboard there are characters that are green. How can I use these characters? For example the sterling pound sign
Hold down the shift key and then press the £ sign.... for € sign hold down Alt-Gr then press 4 shift key is located under the Return or Enter key and above the Ctrl key
Oct 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
How to disable touchpad?????? i end up opening things i dont want to by tapping it by accident and i just want to use the buttons to click for mouse only Acer Aspire 6930
Dear friend please press FN+F7 ( sign of touchpad) Its will locked then. When you want to use it again press same key. Follow the sign which is you press with FN key.
e46ffcb.jpg Thanks & waiting for your feedback.
Feb 06, 2010 | Acer Aspire 6930-6771 Laptop
I donot have anything wrong with my laptop i just
If you are referring to the?< > { } symbols and characters, in order to get to these symbols, hold down the "Shift" key while hitting the key with the symbol you are trying to get. Any keys with one symbol on top of the key and one on the bottom of the same key, pressing the shift key allows for the symbol on the top of that key.
Jan 07, 2010 | Acer Aspire 4720 Notebook
Can not see fn signs on screen acer aspire one
Some computers (like desktops) dont have a fn key. you will have to do everything manually. Usually from the control pannel
Aug 13, 2009 | Acer Aspire One Netbook 8.9" Notebook
Keyboard problem. Key 3, @, #, y, n can't use
you may have shorted your keyboard (spillage??)
if your laptop is outside warranty you can check the connection to the keyboard, by removing the top bezel, undoing the keyboard retaining screws and then check that the ribbon cable for your keyboard is seated properly, If reseating this cable does not work the you can always order a replacement for your keyboard, you can find the part number for the keyboard you have, it should be printed on a tag on the reverse of the keyboard.
May 24, 2009 | Acer Aspire 3680 Laptop
Keyboard removal Acer aspire 8920g
To take the keys off, gently pull up on the top side of the keys until they snap off. Just push them down again and they'll snap back on.
Mar 21, 2009 | Acer Aspire 8920-6671 Notebook
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
381 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
