Question about SanDisk 2GB microSD Memory Card
My Sandisk 2GB micro SD card will not re-format and hence remove corrupted files using the Windows format tool. Plus files will not delete at all, and just reappear!!! Is the card gone for good?
    Scholar:
  • 179 Answers
To be honest, once you're getting this kind of problem, the card can no longer use. You need to buy a new card.
However, I would suggest to try different things first:
1. If you're trying to reformat the card using the SD adapter or card reader, you may want to try to use different adapter or different card reader.
2. You may try different computer as well.
If the same problem occur, then there's no other option but to buy a new one.
Thank you and good luck!
Posted on Nov 12, 2010
I purchase one new memory card. the memory already have password.how to find my password
Posted on Nov 24, 2010
    Habit-Forming:
  • 31 Answers
Before throwing away a possibly perfectly good card try formatting it in a camera instead of a computer.
Posted on Apr 18, 2011
    Problem Solver:
What I did, and it worked, if you use an adapter to insert tthe card into your computer, put the switch on the side in the locked position (down, compared to printed label) and insert it. I did that, and all of the files re-appeared and the card works just like it did before. After that, safely remove it and put the switch back to the original position. Just remember to safely remove every time you take the card out of a computer.
Posted on Nov 14, 2010
2 Suggested Answers
firesnake09
  • 2923 Answers
SOURCE: My Sandisk 2GB micro SD card will not re-format
Posted on Nov 07, 2010
My handphone cant read sandisk micro sd.. how to recover it?
You can connect the sd card to computer with a card reader, then you can follow this sd card recovery guide to recover your files
SD Card data recovery guide
After you get back your files, you can format the card and try to use it on phone.
Jan 26, 2013 | SanDisk 2GB microSD Memory Card
All accidentally deleted.
I would suggest you "NOT" to copy anymore files on your SD Card to prevent data loss or data corruption. Stop using it immediately.
Download an undelete program such as Undelete Plus. I think its a free download. and run the
program to recover your pictures. If you attempt to continue to use your SD Card you are at
higher risk of loosing your data.
Feb 04, 2011 | PNY 2GB microSD Memory Card
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
Hi i am unable to delete files on a sandisk micro sd 2gb. i have tried various programs to delete them. the file themselves say it is 0kb but still says full when its in my phone is says it is full. thanks
ok do you want to delete individual file or clean it completely.
if the memory card has gone corrupt the easiest solution to find out whether its gone faulty or just corrupt would be to format the memory card but this would mean losing all that is on there.
to format your card
1. insert it in your computer or laptop
2. go to my computer and you should see your memory card or it may say removable disk :? (? being a letter which it will name it)
3: right click on card and select format from the drop down menu
4: select quick format and click next
and all being well should be clean and ready to use again if it fails the format it generally shows that the memory card has gone faulty
Jan 19, 2011 | SanDisk 2GB microSD Memory Card
My sandix 2gb microSD mameory card is write protected how will i remove it?
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 29, 2010 | SanDisk 2GB microSD Memory Card
I am unable to copy files to my memory card the system is displaying the error as " disk is write protected "
Dec 22, 2010 | SanDisk 2GB microSD Memory Card
Nov 07, 2010 | SanDisk 2GB microSD Memory Card
I have an 8Gb ScanDisk Micro SD card that got corrupted is there anyway for me to recovery the data off of it
The answer is definitely Yes. You canrecover those deleted/lost pictures and videos from SD Card. But you have to rely on somephoto recovery software as it's the most effective way. Try Card Data Recovery. This program applies advanced algorithm deep scan your memory card and harddrives to seek for your lost pictures and video files. You may get the programhere:
http://www.card-data-recovery.com
Sep 29, 2010 | Garmin SOFTWARE, MICRO SD/SD CARD, EASTERN...
I hve an samsung j700i. I am not able to delete anything from the memory card nor able to formatt it. It is an sandisk 2gb memory card. I have tried to formatt it on another cell but no use. i have tried...
Try formatting your memory card by inserting it in Micro SD adapter then insert this in the memory card reader and then try formatting it using HP USB disk storage format tool. This would probably fix this...
Sep 15, 2010 | Samsung J700 Cellular Phone
2GB microSD Memory Card memory card is corrupted memory card is corrupted
If its corrupted then simply down load hp format tool software. its free google it and downlaod.
install the software and format the micro sd card it will work fine,
Jul 30, 2010 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
499 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
