Question about Health & Beauty
How to open programing mode in pepteller wall coin box...
PROGRAMMING
Posted on Aug 26, 2013
Coins fall directly into change opening on front instead of dropping into collection box
Your coin-mech is jammed and the coins are bypassing the collection box. use the service door key and visually inspect the coin mechanism for a blockage
Apr 22, 2016 | Washing Machines
I removed pulley and gear on drum and reassembled,now when water is poured in it runs right through drain hose.Will this mean programme is in incorrect mode?
LG WFT1071TP To remove coin from bottom don't open drum just open cover of drain valve coin may be out from drain valve.
Mar 21, 2014 | LG WFT1071TP Top Load Washer
I have a coin operated timer control box for my washing machine. Someone turned the power off at the wall and now it won't work
Please confirm if the power was restored. Now If so then you can turn it off once again and wait for few minutes before switching it ON. Tap on sides while the machine if switched off to confirm if any coin was lodged while the power was off. If this is struck within you will need to remove the covers to clear the mechanism and reset the sensor action. Also check if there is power supply within the unit for the functioning of the control board.
Jan 25, 2013 | Washing Machines
Wall-e u comand robot, will not move forward he just turns, can i fix the right wheel?
On the in side of the body (cube) is a white gear the size of a 50cent coin. It is pressed on a drive shaft. The inter ring is cracked and slipping. It makes Wall E turn around and around. I'm looking for a replacement or some one with a makerbot to reproduce it. If any one finds one let me know at. stevepiper@usa.com
Apr 19, 2012 | Disney Wall-E U-Command Remote Control...
I cant open my skype can you give me the reason why they wrote this prohibited access? can you help me ?
Start > Program Files > Skype (right click on it)> Compatibility mode and now uncheck the box.
After performing this step, access your machine in safe mode and clean it using Reginout Cleaner.
Start normally, open your skype.
Thanks.
May 17, 2011 | Skype IM
Fuse box location 2005 toyota corrolla found one under hood looking for fuse to cig. lighter
It is on the drivers side. Find the small coin collection drawer to the left of the steering wheel, the fuse box is located directly behind it. Just open it then lift and pull to remove the coin drawer and you will reveal the internal fuse box
Sep 12, 2010 | 2005 Toyota Corolla
Says I downloaded facebook on my phone and I didn't
Hey welcome to fixya. Hope u 'll be fine
  • U can wish birthday easily
  • Just open the Wall of a person u want to wish. Just write your wish in the text box on His/Her wall and click on Share. Your wishes 'll be shown on its Wall.
  • If u have the coin just select the gift which is also shown on his.her wall, Purchase the gift and share on it wall.
U 've done, Enjoy
Wish u good luck
If it is helpful do Rate me.
Keep using fixya
Thanks
Feb 08, 2010 | Facebook Social Network
Cant find the middle coin on level 7-a! please help!
From " Star Coin Location Guide" by RX7InfinitiIII in www.gamesfaqs.com:
Stage 7.A
Coin 2: In the second "area", there is a cannon on the right sidethat will shoot you straight up. As you begin to fall back down, slide down the right wall. Walljump to the left when you see an opening in the pipe on the left, then enter the pipe from below. You will be deposited next to the coin.
Aug 24, 2009 | Nintendo New Super Mario Bros. for DS
Cant find 2nd coin in world 6-2 on new super mario ds
The second coin is around the very middle of this stage.
It can be rather easy to miss if you take the first pipe near the middle of the stage up into the clouds.
If you skip this pipe and enter the next one and it'll launch you over a rock wall and over another pipe that'll send you back.
If you continue forward you'll notice there is a ceiling of rock above you with an open area. Wait for the water to rise and swim up to the top.
The second star coin should be there.
If you take the first pipe into the clouds then you'll exit out of an orange pipe.
You can back track to the left and get the coin that way too.
Though you'll need to wall jump to get over the rock walls in your way.
Incase you have trouble with wall jumping I'll give you some tips.
To wall jump you just jump against the wall and hold the direction the wall is in. Mario should lean and slide against it. Press jump and you'll fly off in the other direction.
If you are between two walls you can use this technique to jump back and fourth up the walls in old video game wall jumping style.
Just alternate directions accordingly and press jump when you are on the wall.
The timing shouldn't be too hard, but remember to practice it till you get it.
don't worry about the time either, you can always try again if you want to.
Good luck and have fun.
Apr 20, 2009 | Nintendo New Super Mario Bros. for DS
Want to swith from free mode to coin charge mode
there are buttons inside the coin door for programming. one to get into the programming mode, and the other(s) for selecting options. the options will appear on the screen. you should be able to chose it from there.
Mar 27, 2009 | Namco Ms. Pacman Galaga Cocktail Video...
Health & Beauty Logo
102 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
