Question about Belling FarmHouse 931 Gas Kitchen Range
Main oven will come on but gas will not increase to bring it to the correct temperature model Belling Farmhouse Model 111
Did you ever get an answer to this problemm
I have the same problem...answer please
Brian
Posted on Jan 29, 2011
Tip
Common faults with Belling FarmHouse 932
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling FarmHouse 932 Dual Fuel (Electric...
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
The main oven flame wont stay on when lighting
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 06, 2010 | Belling FarmHouse 931 Gas Kitchen Range
Belling Farmhouse Cookcenter Model 111 main oven wont reach temp
Same problem here too. Plus the in-game assisted oven has a similar problem inasmuch as the flame goes straight to max and won't reduce. Please help
Apr 05, 2010 | Belling FarmHouse 931 Gas Kitchen Range
The ignigter in the oven keeps clicking all the time the oven is on ? the model is 911
The clicking is not in the oven. You have a bad surface burner switch. Open the front control panel to access the surface switch. Remove one wire at a time for each surface igniter. They are located on each burner valve stem. When the clicking stops, that will be the bad switch. Replace it.
Jun 12, 2009 | Belling FarmHouse 931 Gas Kitchen Range
Belling FarmHouse 931 Gas Kitchen Range Logo
203 people viewed this question
Top Belling Kitchen Ranges Experts
paulcarew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
