Question about GE WHRE5260E Top Load Washer
GE Top-loader Leaks Water from Vertical Tube Behind Tub on X-Large Loads
I actually have a WJXR2080T2WW model GE (3 controls/1 master - 8 Cycle 2 Speed), it's about 12 -13 yrs old. It just recently started leaking some water, mostly on X-Large Water selections, a little on Medium load and I believe it's coming from a Vertical cream opaque tube that's to the rear almost behind the washing tub on the left side. I don't know what this tube is for, it starts somewhere at the top of the machine (can't see it) and runs down to near the bottom of the washer chassis and then has a short 90 degree curve to an opening. No hose is connected to the bottom open end.
When we've had water on the floor after a cycle, this is the only place that there is water dripping from. None under the tub or the water pump. It does seem that the water level is a bit higher than normal on the X-large loads, but I can't be sure, not recalling what it looked like before. Medium loads water level appears normal, and we still get a bit of water on the floor from under the machine.
Would appreciate any educated fix-it experience or clues as to what the problem is and how to fix the problem.
  • 10 more comments
  • ksbrcupofjaz Jul 06, 2008
    Geez, I guess no one bothers to read what I wrote for the symtoms. Hey guys, I said it's all about the water level!! Not agitating, not transmissions, not a LEAK!!
    The "small / medium / large load" selector is not supplying the right level of water per the selection. Small is delivering MEDIUM, medium is giving LARGE, and large is too much enough to spill over and apparently down the over fow tube.
    Sometimes the washer does NOT do the SPIN part of the cycle (the machine washes and agitates just fine).
    So I want to know, what part (I assume electrical) do I replace? What does actually control the wash level??
  • ksbrcupofjaz Jul 07, 2008
    mikedurland -Thanks for the follow up answer, sorry for the confusion on the symptoms. My second post about the problem I elaborated that it wasn't a leak as first thought, because I couldn't see the over flow tube behind the tub. I didn't know at the time that is what that vertical tube was for.
    Can you explain what " if the basket is moving while it is agitating " ?? Not sure what the "basket" is? As long as I've had this washer (12 years) from new, the whole tub rocks rotationally in unison with the agitator. As far as I can determine, the wash action is all normal, except that it's been sometimes not doing the spin-drain cycle the same times it's not delivering the correct water level to the selected load setting.
    Does the Load Switch completely control the water level, or is there another component that also does this in conjunction with the switch?
    Would the malfunctioning Load switch also cause the missed spin cycle (it just drains water, but doesn't spin)??
    Thanks for helping me with getting to the specifics of this problem.
  • ksbrcupofjaz Jul 13, 2008
    Tried adjusting the small threaded hex head screw you suggested, but no help there. I'm pretty convinced though that it is still the culpret.
    How do I find the part number for the load selector for the year and model of our washer (WJXR2080T2WW model GE)? And where are some good places to buy that part online (cheap of course)?
    mikedurland - Thanks for the suggestions.
    mikedurland - Tried the adjustments to the hex head screw on the load selector, no difference. How do I find the actual part number for the selector for my WJXR2080T2WW model GE washer and any suggestions for a cheap place to order it from in the Internet?
    Also, will the selector switch come pre-adjusted correctly?
  • ksbrcupofjaz Jul 14, 2008
    I did a search for the part using GE Washer Parts and the model number and found a site with the part for $22.99 + $5.99 for priority mail. Very nice folks at helpfulitems.com in Texas, will ship it the same day. Hate eBay, dealers are too slow to ship, 3 -5 days and they over charge you for shipping and then send it by Parcel Post - the cheapest and slowest way possible.
    I was just thinking about that hose from the Washer-Pressure-Water-Level-Switch. One parts site had some install suggestions from parts buyers, and one guys said to be sure to "blow the hose" to create vacuum when you "estimate the water level". Huh?? Not only didn't make any sense, it was the worst mangling of the English language I've seen in a while.
    So how do the "pros" install that hose so the vacuum is correct for the water level?
    Thanks for your help.
  • ksbrcupofjaz Jul 20, 2008
    mikedurland,
    Replaced the load selector switch - easy - but the water levels are still screwed up and the washer doesn't put water in for the rince cycle and doesn't do the spin cycle.
    I didn't replace the vaccum hose because it looked good. cold it be that, or is there a sensor somewhere for the Load Seclector Switch?
    If it's the hose, how long is it and what type / guage? Can I just buy hose at a Home Depot? And where does it go to  and how do I get to that location?
    If it's a sensor of some kind, what is it called so I can search online for it and how do I get to it?
    Boy, I'm just about ready to just buy a new washer (NOT GE!)
    Thanks for your input.
  • ksbrcupofjaz Jul 30, 2008
    mikedurland,
    Your suggestion of checking the hose from one end to the other was the last key in making the GE Washer work like new!!
    While I could not find any leak in the hose itself ( I verified the hose from the water level box in the side to the tube to the Level Selector with a vacuum gauge), I cut off a slight amount at each end where it had widened from the old connections so it was a tight fit again at each nipple. I also cleaned out the nipple entry at the water level box on the tube as best as I could. It doesn't look like there is a way to take that part off to really clean it.
    Never the less, the water levels are perfect again, the washer does all the cycles and spins correctly, and works nearly as good as new.
    I got a tip from my 85 year old Mom - she says that she and all her friends always do a long low level cycle with a 1/2 gallon of Vinegar added to the water to desolve the hard water mineral build ups in the system every few months. She has a 24 year old Whirlpool washer that still runs like new and never any repairs. Any credibility to that "Old Wives Tale" (sorry Mom)?
    mikedurland - you are the King of DIY Washer Repair Sleuthing!
  • 481 Answers
It sounds like the basket is not locked when it is agitating, if so the water will climb the wall during the wash cycle and leak out of the overflow (which is the plastic tube you described). if this is the case, it is a transmission brake problem. it can be fixed by a professional, but you might want to look into buying a new machine.
Posted on Jun 27, 2008
  • 4 more comments
  • Mike Durland
    Mike Durland Jul 07, 2008
    • yes i read it it said "It just recently started leaking some water"
    • i also read "It does seem that the water level is a bit higher than normal on the X-large loads, but I can't be sure"
    • so now your saying that it is definitely higher and now your sure that is what the problem is.
    • okay
    • if you can watch the water level go up and over the tub and onto the floor before the machine starts to agitate then the water level switch is bad or needs to be adjusted.
    the reason why i suspected the transmission brake problem is because it is an extremely common problem with those machines and it matched the symptoms you described in your first post ; exactly. i am trying to help you with YOUR problem for FREE. at least you can be polite.
    • if it does not overfill before agitating, then watch the washer when it is agitating. if the basket is moving while it is agitating then you know it is the transmission brake problem.
  • Mike Durland
    FIRST POSTHEADLINE:GE Top-loader Leaks Water from Vertical Tube Behind..
    SECOND POST
    not a LEAK!!
  • Mike Durland
    yes, a malfunctioning water level switch can cause the machine not to spin. and would cause the problem with overflowing too. you may be able to adjust it, the adjustment screw is the blue one in the picture. the switch has a diaphragm inside that senses the pressure in the tub, and if it thinks there is too much water in the tub then it will not spin. just loosen the screw 1/2 turn to a full turn and try it again. you need a t20 torx screwdriver to take off the control panel, the screws are along the top of the control panel. the part is only $30 ifyou want to replace it. the basket is the inner tub that the clothes go in, it has holes in it.
  • Mike Durland
    Mike Durland Jul 13, 2008
    http://cgi.ebay.com/GE-WH12X10065--Washe...
    • here is one on ebay for $12.40 + $7 shipping
    • the part number is WH12X10065
    • repairclinic.com has it for about $30 + shipping
    • also check the tube that connects to it for possible air leaks, maybe even replace it just in case
  • Mike Durland
    Mike Durland Jul 14, 2008
    • the water level switch is already adjusted from the factory, just replace it and plug in the wires.
    •  the pressure hose is just as easy, just slip the ends on as far as they go and your done
    • (make sure you use the same route as the old hose, they have it going that way for good reason).
    • the only stipulation when installing the hose or the water level switch is that the washer has to be empty (no water in it).
    • no need to "blow the hose" :) he he
    • that is funny, i read some of the suggestions and solutions posted on these sites and they are ridiculous!
  • Mike Durland
    Mike Durland Jul 20, 2008
    You can try changing the tube, just take the old one to home depot and match it up. it just runs from the switch to the side of the tub.
    • as far as the other problems, i am stumped.
    • the only sensor to the amount of water in the tub is the switch you just changed.
    •  the only thing i can think of is if you accidently put the wires in the wrong place when changing the switch. i know its only 3 wires but i have done it before.
    • also check where the pressure tube mounts to the tub and make sure no dirt or lint is in or around it. i have had a problem where the tub would just keep overflowing because of this problem.
    • sorry you are having so much trouble with this machine, i know how frustrating it can be.
What is the purpose of the flood hose? we have a ge wjsr2080t2ww washer. when we use the power wash cycle in super capacity mode as a minute after it starts agitating the water comes flooding out from...
the purpose of that tube so it anywater that comes out of it goes through it and directs the water down the back and away from the motor. Now the bigger issue is why is water coming through that tube.What i suspect the reason of that is that the transmission is defective and the break is that internal to the transmission is slipping so the inner tub turns during the wash cycle force water up the side of the tub into that tube.during the agitate cycle the tub is not suppose to move at all and stay locked into place,but instead its moving where the water is forced up by centrifical force too and out the top of the tub cover,if it leaks with only a small water load it will leak worse with a large water load. if this is what is happening and the tub is rotating on agaitate cycle teh fix for that is to replace transmission which in most cases cost as much as replacing the washer would be
Aug 04, 2011 | GE WDSR2080D Top Load Washer
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
My GE top loader leaks at the spin cycle when it is letting out the water
Sounds like the tub seal under the tub where the transmission goes into the tub. Replace the trans and seal.
Mar 15, 2011 | GE WBSR3140DW Top Load Washer
Hotpoint washing machine model vbxr1090b2ww leaking from bottom of unit
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
Feb 13, 2011 | Hotpoint VBXR1090B Top Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
Washer leaks now when doing large loads.
pop the front panel you can do this with a putty knife. where the top is 2 inches down you will see a creas use a flash light you will see the 2 clips push in on the clips and pull out you will be able to access where the tub is to see where the leak is comeing from
Jan 04, 2009 | GE WBXR3100B Top Load Washer
GE WJXR2080T2WW Washer Fills with water - then stops
older machine would have been easier to fix ..remove front ck small hose to tub left side remove hose and clean crud from end as much as possible if still overflowing replace water level control..new machine may be timer or lid switch not closing properly remove front to acess lid switch on right side
Jul 22, 2008 | Washing Machines
GE Top-loader Leaks Water from Vert Tube Behind Tub on X-Large Loads
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 18, 2008 | GE WBB4500EWW Top Load Washer
Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 16, 2008 | KitchenAid KAWS700L Top Load Washer
GE WHRE5260E Top Load Washer Logo
729 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
