Question about Dell Laser Printer 1100
I have a Dell 1100 printer. The pages are now coming out with black speckles and marks on top of the print. Does it need a new cartdrige or wi there something else wrong?
  • 231 Answers
You will have to replace the drum unit and the toner cartridge.
Posted on Nov 12, 2010
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
My printer is not printing..page comes out blank. inside, all the lights are flashing on the ink cartridges...any ideas what's wrong? thanks
this message means that the cartdriges are empty...
if you have bought new cardridges and lights still flash then the printer just dont recognize them right.
possible cause 1:
dirty cartdrige (or printhead) chip contacts > clean them with alcohol and cotton (switch printer off first).
see the chips in this photo:
https://secure.datatekusa.com/images/canon%20PGI5.CLI8%20refillable%20cartridge.jpg
possible cause 2:
bad printer controller: the chip in the printer that communicates with the cartdriges is gone mad... take the printer to service...
all the above are valid assuming you bought original cartdriges if not then do so...
Sep 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
We ran some aftermarket (non dell) toner in it and quit when the pages were coming out with color haze & streaks of various colors on them. Have vacuumed out old toner powder and installed genuine dell...
You need to be using dell toner for this printer not aftermarket becase the tecknolag it uses to do the printing will only work on the recamended toner catrages
May 02, 2009 | Dell 5100cn Laser Printer
Cannot print in black only
because you NEED functioning colour carts in machine or NO Print
Apr 27, 2009 | Office Equipment & Supplies
Dell 1815dn laser printer prints completely black pages
1. Charge – Print Quality (PQ) -- The charge roller evenly distributes a negative charge on the photoconductor (PC) drum. This evenly distributed charge acts as the film that is discharged (exposed) by the laser to create the latent image.
a. Print Quality effected: Faint, Entire Black background, Grey Fog/Haze
b. Parts Involved:
i. Drum -- A drum cartridge is coated with a photoconductive material that allows electricity to pass when exposed to light. As an example of why this can be the failure, if you leave a drum out in light long enough, you will get dark backgrounds or just black pages. However, drums do wear out over time too; specifically the photo material the drum is coated with. As this degrades, more of the positive electricity on the inside of the drum gets through and grabs toner, as if the laser wrote to every square inch of it. A damaged or defective PC drum can cause black streaks/lines, voids, speckles and various other print quality problems.
ii. Charge Roller Also known as the BCR or Bias Charge Roll. The charge roller pulls double duty. It energizes the outside of the drum with negative energy and as a result it cleans any previous latent images. If the charge roller were failing to energize either due to the HVPS or the charge roller itself, it wouldn’t clean any previous unused toner deposits from the last revolution would start to accumulate and appear on paper more and more causing haze. A missing charge roller causes completely black pages.
iii. HVPS – High Voltage Power Supply -- Responsible for charging components such as the inside of the drum, the charge roller, and transfer roller. If the HVPS does not give enough to the charge roller it can fail in erasing the drum, causing entirely Black pages to be printed.
Apr 16, 2009 | Dell 1815dn All-In-One Laser Printer
'Speckled' Printing
Do you have the owners manual? Did you cancel the document from the computer and turn the printer off for at least 30 secs. The speckled print and lines are usually caused by a defective toner or worn drum. Usually a drum will last for 10 thousand or more cycles. But sometimes prematurely wear out. Make sure you are absolutely using a genuine Brother OEM supply. Generics have a high failure rate. This is not a heavy duty printer. When you need a drum and toner together, it will be just as cheap to buy another low end Brother printer.
Mar 30, 2007 | Brother HL-2040 Laser Printer
52 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
